20-04-2008, 01:52 PM | #1 | ||
4dlvr
anyone no the rite way to change the headlight globes on a lr focus???
i tried from behind in the bonnet and realized it wasn't possible, then i thought the light might come out, i took the 2 viewable screws out but the light still wouldn't come out, theres a screw that i just cant find... please help someone :
96 EF FAIRMONT Garrett gt40 turbo , iceman plenum, head ported, polished and balanced, wade turbo cam, wade double valve springs, bosch 023 fuel pump, 36lb injectors high flow cat, 4' dump and 2.5' redback exhaust. 215rwkw @7psi |
20-04-2008, 02:57 PM | #2 | ||
Knows nothing. Apparently
I went through a stage where my local spares place was getting a batch of really dodgy globes and I was replacing them every second month nearly.
It's not an enjoyable job. To change the passenger's side globe, I was removing the battery and the battery box. from there I could open the little flap on the back of the head light. It's a small opening, there's not a lot of room and you can't really see what you're doing. The driver's side was a little easier, but not much easier. I don't recall having to remove anything, but I think I did have to move a few hoses around. They unclip quite easily and free up a little bit of space. However, I could be going about this completely wrong so if someone else out there knows an easier way to do it, I'd love to hear it. I was only following what it had in the owners manual, and even then it only tells you how to open the flap on the back of the headlight.
2008 Electric Orange LV XR5. With dreamscience strategem SCT, K&N 57i Gen2 cold air intake for more fun and demonic vaccum cleaner noise!! 1975 Mitsubishi/Chrysler GC Galant 2-door Hardtop. 4G63 DOHC heart transplant nearly complete!
Check out the build over here |
20-04-2008, 06:30 PM | #3 | ||
The manual for the car will tell you step by step...but it is a very hard process and its something that I don't enjoy doing on my car. Best headlight globes I have used is the genuine ones believe it or not. Lasted me 4 years. I put blue vision in and they blew after 3 months. So I forked out $60 for genuine and I don't have a problem
2015 MK7 VW GOLF GTI __________________
Previous Cars 2002 AUIII XR6 1995 EF Falcon XR6 2003 LR Focus Zetec 1989 KE Laser TX3 |
20-04-2008, 06:51 PM | #4 | ||
Old enough to know better
There is no easy way. It is done as the guys describe it. If you've taken out scrws....put them straight back!
You have to flick down a large wire clip from the top of the black covering of the headlight in the engine bay. As TJ says, try the driver side firts, theres more space. Also try using a small mirror to see what you're doing. there is no way of getting your head behind it
21-04-2008, 05:54 PM | #5 | ||
I beg to differ steve.
I managed to get my head in the spot where the battery box lives. then again, I got a little head (goes with the little body) Didn't really help tho, still couldn't see anything.
22-04-2008, 12:07 PM | #6 | ||
4dlvr
ok its been done, thanx heaps.
hard but not nearly as hard as i thought it was, cheers
30-04-2008, 10:37 PM | #7 | ||
I wanna XR5
its easy, remove the one screw at the top that attaches the assembly to the front bulk head, the whole head light unclips out. thats for the LS
The power steering res is down below the right hand head light. my 2 cents. WHOOPS DID NOT READ YOUR ORIGINAL POST PROPERLY
Great Wall X240. Bouncing around the APY Lands Ex Ford owner and member of this great site for ages. South Australia, where the RIGHT hand lane is the NEW LEFT lane??????!!! %&#@* Last edited by 20focus05; 30-04-2008 at 10:43 PM. |
