#1 | |||
No longer driving a Ford.
My brother is seriously considering buying an EA Ghia that apparently has an ED XR6 engine in it, but asides from that, its a stock EA Ghia (3 speed auto, electric everything, etc.). Apparently it's in VGC inside and out, with the only things being wrong are the front bar is drooping a bit and one of the heater hoses is leaking and needs to be replaced. The seller wants $1500 and it's not coming with a RWC, but it shouldn't need much (if anything) done to pass RWC. Does this sound like a fair deal, or is that too much for what it is?
![]() Join Date: Dec 2004
Well as long as it doesn't need much for a roady, that would be well worth getting! EA Ghias are a *very* nice ride indeed, a mate of mine had one and it was a damn quick car (5 speed, bought for $1700 with RWC).
The 3 speed can easily be replaced with a T5 too ;) ;) I'm not one to normally advocate a T5 over an auto, but in the 3 speed's case I'll make an exception... Let us know what he decides on! Cheers mate -Dave- |
#3 | |||
Beware of mood swings!
Location: Western 'burbs, put your bullet proof vests on!
Aaaaaaaand I still think he should look for an EB. :nutsycuck
1993 EBII GLi Auto, 4.0L MPI rebuilt by JMM, JMM Dev1 kit, JMM Hi Flow Cat, still to hit the quarter mile. :Up_to_som
Dyno Sheet-14/07/05 |
#4 | ||||
So what does everybody else think? EA Ghia with 3 speed auto and ED XR6 engine running on both LPG and Petrol, apparently in VGC, worth $1500 or more/less?
B-Series Powered!
Considering its on gas, and it has an ED motor, then I would get it if i were him.. how many km's is on it?
Its only real let down is the 3speed which can be changed if you want.. Tell him to try and bargin with the seller a bit..
2003 BA Futura Pacemaker 4490's, 2.5" metal cat, 2.5" mandrel bent exhaust, hi-flow air filter, more to come! |
#6 | ||||
![]() Not sure about how many kms on it, hard to tell seeing as it's not the original motor.
B-Series Powered!
Get him to ask the seller, they SHOULD know..
There could be a problem with dodgy engine numbers when he comes to register it....you'd wanna check that out...
#9 | ||||
B-Series Powered!
If its currently registered, it should be a legal motor, correct?
#11 | ||||
#12 | ||
B-Series Powered!
Alright, sounds an alright deal, good luck.. tell him to ask how many km's its got..
#13 | |||
Anybody else think it's potentially a good deal?
#14 | ||
Afterburner + skids =
Its a good deal potentially. But he had wanna check it out properly first.
#15 | |||
If it all checks out, I reckon it sounds like a good deal. Throw a T5 in there with a 3.23LSD and he's laughing.
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
#16 | ||
RAGE Engineering
Alot of people are talking about changing the tranny and what not. Once that's done, it will probably owe him more than the car is worth.
If he is buying it with the idea to modify it to suit, then he'd be much much better off getting the right car to begin with. Old Falcons are a dime a dozen.
If it doesn't fit, use a BIGGER hammer |
#17 | |||
Former E-Series Member
On the other hand, paying top dollar in labour for every little heater hose and spark plug replacement will make anything that age a pricey car to run. Best of luck with it. |
