Old 31-12-2007, 06:20 PM   #1
huey
Default Laser KF 1990 temp probs
Hi All,
We have a 18i KF 1990 laser which has always ran with the temperature dead centre in the gauge.We recently had a bit of a leak from a hose due to a loose jubilee clip and we only noticed this when the temp ran up.I topped it off with water to get haome and forgot about it.
Exactly 4 weeks later temp was rising again, had to add more water to get home and the next day I flushed the system and refilled with new coolant.
Now we seem to run in the centre of the temp gauge till we go above 80Kph (RPM seems to have no bearing) then it rises to nearer 3/4 to the top of the gauge and fluctuates up and down slightly. Its never got to overheating temps but it is a worry as it always used to remain very still.
Any Ideas please?
Huey
huey is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2007, 06:32 PM   #2
290v
290v
290v's Avatar
Have you checked to see if the Thermo fans are cutting in and out if it is rising in temp at idle to extreme but cools when driving then check the fans
290v is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2007, 06:51 PM   #3
huey
No the fan does cut in and out. The seems to rise whilst on the freeway at 100kph then fluctuates up and down whilst at speed.On coming to idle it seems to cool a little but does not settle as low as it used too.
Real confused.
Huey
Old 31-12-2007, 06:55 PM   #4
dirty hands
Over Thinker
dirty hands's Avatar
remove the thermostat
place it in a small sausepan of boiling water and see if it opens fully
it may be sticking ......try that first
My car goes Brumm Brumm
dirty hands is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2007, 07:03 PM   #5
huey
Thanks guys will give it a go.
Huey
