i just bought a TX5 1988 2L 5 speed man and it has been sitting i think for about 2 years ...
3 probs tyres ... easy fixed lack of fuel to the carby ... replace the fuel pump and filters ![]() clutch pedal goes straight to the floor ???? any ideas ... can someone help me the motor isn't siezed it fires when fuel is fed direct into the carby and runs but it feels like there is nothing between the clutch pedal and the clutch like it is disconnected does anyone have any pics of the clutch linkage assembly??? thanks yall |
Over Thinker
if clutch connection is a cable the cable has broken
if hydrualic the master on the firewall is bypassing internally or the slave cyl on the gearbox is hop under the dash pull back the boot of the clutch master cyl see if there is oil leaking pull back the boot of the slave look for oil to check you bleed the system at the slave if air is present then there is a leak refill the master to bleed you need two people one pushing in the clutch the other relaeing the bleeder at the slave then retightening before the pedal is raised if still no clutch then replace the slave or master or the pressure plate or cluch is worn or damaged thats a gearbox removal
My car goes Brumm Brumm Last edited by dirty hands; 17-12-2007 at 09:27 PM. |
thanks dirty
went out today and bought a haynes reapir manual from completeteardown and rebuild ![]() great pics ... from that the only thing i can't do is shave the head ![]() i had a shock ... slave cylinder from ford $238 from repco $47.99 wtf ???? didn't even ask ford for a quote on the fuel pump it was $87.99 from repco sigh i had almost forgotten the mark up on auto parts :( thanks again dirty |
Over Thinker
repco is ok sometimes super cheap or bursoms can do netter
try a brake/clutch shop for a price on the parts they may do a better deal as always shop around . fuel pump is a good price make sure you use a sealant around the fuel pump gasket
My car goes Brumm Brumm |
Also you can try the wreckers. Even Mazda 626 parts of the same age should be interchangeable.
Ford wanted hundreds of $ for a new power window motor. Got one from the wreckers for $160 and installed it myself ;) |
hello its me again
![]() we got the car back here ... fitted new fuel pump and slave cylinder it was totally siezed then bled the cluch hydraulics. she runs really well :O took her for a quick spin down the road :0 no hiccups except ... it doesn't have parker lights or tail lights? *** checked fuses and replaced *** referred to haynes book got lost in the wiring diagrams :( any ideas? still not bad for $400 plus parts ![]() |
Over Thinker
they had a problem with the earth wires at the back
and bulbs blowing one side spray the bulb holders with wd 40 and clean them as best you can try them again problem can be in the light switch or relay in the system (auto electrician or mechanic with knowlage ) use a different coloured high lighter on the lines to make the wiring diagramme easier to follow
