Old 22-05-2005, 11:21 PM   #1
jaym
I Wish I Was A Post Whore
jaym's Avatar
Default New Engine Heaps Of Smoke
Sorry i know its not a ford but, can someone help
Put new engine in mates gemini the other weekend every thing is new motor.
runs perfect but blows shit loads of smoke,
Why is it so smokey??
XR8 On 20s W00T W00T
www.aufalcon.com/jaysxr8
jaym is offline   Reply With Quote Multi-Quote with this Post
Old 22-05-2005, 11:24 PM   #2
mr_efxr
Not your average EF Wagon
mr_efxr's Avatar
What color smoke and when?, idle, on accel or what? Whats the smoke smell like to you?
Power by HeadTech Performance Williamstown
The recently SOLD 95 EF Wagon 5spd NA SLEEPER
The Daily cruisers now *95 R33 Skyline GTS-T RB25DET *93 Lexus GS300 2JZ-GTE
Car enthusiasts visit Unique Cars and Parts
mr_efxr is offline   Reply With Quote Multi-Quote with this Post
Old 22-05-2005, 11:42 PM   #3
jaym
jaym's Avatar
its white smoke, was doin it all the time, now only when revs pick up, and its hard to say what it smells like it doesn't really smell
Old 22-05-2005, 11:57 PM   #4
SpoolMan
Solution Was Boost 4?, 6 & 8
SpoolMan's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF events and sponsorship. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Everything you do to help this place run smoothly! Technical Contributor: For members who share their technical expertise. - Issue reason: The awesome Technical and Service how to's in the FPV /XR6 /G6ET turbo threads..  and his own build threads that inspire people to have a go... enabling people to save money and realise the dream of working on their own cars as well.
looks like the rings are no good..
where did you buy the engine?
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED
2017 GT Mustang Plenty of RWKW
SpoolMan is offline   Reply With Quote Multi-Quote with this Post
Old 22-05-2005, 11:59 PM   #5
brenx
brenx's Avatar
If the cars auto check the vac module isn't stuffed. I know quite a few people who have bought engines due to a $35 part being worn out. When worn you can suck the trans fluid into the manifold.
74 XB Fairmont (street car) 11.07@123.02mph. 08 LV Ford Focus XR5 (daily).
Tuned by Hallam Performance
brenx is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2005, 12:03 AM   #6
jaym
jaym's Avatar
rings would want to be good just got back from rebuild
its a manual,
Old 23-05-2005, 07:17 AM   #7
MO
MO's Avatar
Valve guides/seals maybe,have you done a compression check?
FORD RULES OK
The more I know ppl the more I love my DOGS.
2011 SY Territory Limited Edition TS
2000 AUII SE ute IL6
MO is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2005, 07:53 AM   #8
jonbays
TL40 Wagon?
white smoke? not blue or black?
Not sure about rings then.
Any possibility its sucking in auto trans or brake fluid from a stuffed vacum modulator or booster?
jonbays is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2005, 04:58 PM   #9
WeirdEL
Posts: n/a
Maybe the oil control rings are upside down? I've seen it on a car once - pulled the head off and the dishes in the pistons filled up with oil on the starter. Took ages to get the oil out of the exhaust, too. Glad it wasn't my car or me doing the work.
Old 23-05-2005, 06:30 PM   #10
jaym
jaym's Avatar
mmm might check breaks as we changed master and booster when we changed motor
Old 23-05-2005, 06:44 PM   #11
mr_efxr
mr_efxr's Avatar
It sounds like its burning oil. Could be a case of the rings by the sounds of it.
Old 23-05-2005, 11:01 PM   #12
gtfpv
GT
gtfpv's Avatar
sounds to me like brake fluid disconnect the vacuum hose going to the brake booster and plugit up run the engine for 5minutes and see if it still blows white smoke.
gtfpv is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2005, 09:04 AM   #13
rob_o
rob_o's Avatar
If its oil, wouldnt it be blue smoke? I thought white was when water was gettin into the motor.
rob_o is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2005, 09:32 AM   #14
jaym
jaym's Avatar
nah man that would be steam your thinking about.
havn't cheacked if its breaks yet, as he hasn't come around, will check it tonight
Old 24-05-2005, 05:45 PM   #15
rob_o
rob_o's Avatar
hmmmmm yeah possibly. I was just told once that if water got into the engine then the car actually smoked.
