#1 | |||
Is it possible to wire the dome lights so that they have the ON - OFF - DOOR fuctionality.
Nathan 2005 FPV BF Super Pursuit The new toy (now sold) The SP The old ute (sold) www.aufalcon.com/nc1183 Build Thread Quote:
#2 | |||
Miami Pilot
![]() Join Date: Jan 2005
#3 | |||
You can't stop the signal
You can rewire the standard switch(the slider on the side) to do this but it will involve cutting of the switch loom, some rewiring and you will loose the high/low cluster light settings.
I'm sure it's possible because i just installed courtesy footwell lights (neons actually), that i can manually operate through the headlight switch slider. I did this because my cluster is LED's and the rest of the car's instrument lighting will be changed to LED's soon anyway, so the high/low light setting is of no use to me. They way i have wired my lights is they will come on when ever the dome lamp comes on, and Bottom position - Off - only come on when a door is open Middle position - On - They are on but the dome light is not. they stay on regardless of ignition position. Dome light will come on when a door is opened Top position - On and dome - This position works as normal So it is possible. If you want a wiring diagram made i should be able to do, but what level (high/low) do you wanT the dash lights to be at? Cheers
![]() Join Date: Dec 2006
I put a small switch up above the seat belt in the creamy plastic part near the roof, I cut into the dome light wire to turn it off, turn it on and it works as normal. Turn it off and it won't come on at all even with doors open.
Sorry cant remember the wire colors now. |
I realised the other day it'd be nice to have an OFF switch for it ... especially when the door ajar switch in the actuator fails ... and the interior light stays on ... or worse still flickers while driving at 5am to work in the morning.
I really was not in the mood for a disco at 5am. At least pulling the CRT Lamp fuse didn't immobilise the ute .... I just didn't have interior lights for a day or so ... thank god. I think the driver's door actuator shorts out in heavy rain for some reason ... and thinks the door is open.
