Drag Racing Discuss Drag Racing here be it dirt or tarmac. Sponsored by Sydney Dragway. |
Turbo God
Had a good and bad night last night. I ran a new PB of 11.033@122.39 I had 3 runs and all were better than my previos best of 11.587@123.01. The only problem i had was the car running out of fuel before the end of the run. I was 7mph and 0.5 seconds quicker mid track before the fuel surge. I'll be out next week and hope to have the fuel issue sorted.
RUMBLE 385rwkw's 10.688@128.28 RIP BOOF 28/02/03-20/08/04 12.24@115.38mph .....HPF..... |
AFF.com.au
PB is a PB geea, well done mate.
btw, took your advice on tyres, all my customers stoked. take care. |
missing the panther
Well done on your PB hopefully that 10 sec quarter is only a week away,good to see all that hard earned money and time starting to pay off.
![]() Join Date: Jan 2005
Isn't the record for the quickest XR6T in Australia 10.98? If you can beat that you'll be set! I guess it is the second fastest XR6T now anyway. Good on ya.
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
Last warning
wow :o
10 seconds are there for the picking now. thats unbeleivably quick
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
Well done ! What did you do to drop the 1/2 second ???
Huge effort Craig, not far off the APS and C & V record of 10.98..and the mph is huge too!
Uterus M.I.A.
358.7rwkw's
11.033@122.39 Your so close to the 10's with that PB. Bet you'll be out there at every chance now to get that 10second slip
Giddy up.
Top effort, makes me want to get a T next instead off a Boss, It has me thinking I'll admitt.
#10 | |||
I will always love V8's better than anything else...but if you dont mind the odd 1/4 fang, the T's are great bang for buck with a few grand spent on them ![]() |
#11 | |||
Giddy up.
#12 | ||
NO CARBON TAX
well done buddy, go the 6 packs!!!!
just think mate 10.99 you need a cage, more weight to push. thats one fookin fast ba. good stuff
THE WORLDS FASTEST BISCANYE BLUE EB FALCON WITH EB BLOCK AND HEAD!!! NO AU **** THANKS Atomic performance engine, powerglide, coan converter, gtx55 turbo, 2000hp plazmaman water to air, 100mm throttle body, twin 50mm gates, side exit exhausts, 18 x 2200cc injectors, ems 8860 and race dash....... 7.83 @ 177 MPH 1100+ rwhp @ 40psi the first 7 second sohc ! eat it 1993 eb falcon 15.4 @ 90mph (tow car) |
#13 | ||
NO CARBON TAX
what fuel level were you running??
mine does the same with low (1/3) tank around 300m mark
#14 | |||
Turbo God
The car was tuned with VP109ron racing fuel. To save the cat and reduce weight the exhaust was dropped and the seats taken out. I'm still running the Nitto's. The car was awesome and the only problem was the car surging through not being able to pick up fuel. We thought we had this solved by having a little pump at the back of the tank pumping it ot the swirl pot but it. Unfortunately not. It seems that the faster the car goes the more fuel it needs to avoid this happening. the first run i had 1/4 a tank and coasted the last 100m for an 11.52. I added 15 litres and then had the same problem but this time only for the last 70m or so. I added another 10litres and with a little wheelspin (it was 1125pm and getting damp) i ran an 11.22 with the problem only happening for the final 40m or so. It looks like i'll need 3/4 of a tnk to solve this. For next week only there will be a surge tank fitted and hopefully this will do the trick. Rob and Ian @ HPF were great and hopefully next week will be my night. Just like to add how immpressive Rod's first up run in his pursuit was 11.8 for a first up effort is a huge achievement and those involved deserve a lot of credit. Look forward to watching your times tumble Rod. Heres my slip. ![]()
#15 | ||
NO CARBON TAX
what power diff from pump fuel to race fuel and how much power did you gain from removing exhaust?
off topic........ i made up 2 inch screamer pipe from my wastegate today venting to atmosphere, will see how it goes next week.
#16 | |||
Turbo God
The car went from 328.7rwkw's on BP ultimate with a booster to 358.7rwkw's with the VP109ron race fuel.
#17 | |||
Saving Water Filthy again
Steven
Blood Orange BA FPV GT-P. Again, now I am complete |
#18 | ||
Solution Was Boost 4?, 6 & 8
Well done Craig, very fast awesome time.
good stuff putting the ticket up but we all seen your run there is no doubt.. good night for thr Blue Oval.
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED 2017 GT Mustang Plenty of RWKW |
#19 | |||
Turbo God
#20 | ||
Bring back Ambrose!
Well done Craig.
When you heading to AIR next? It gets awfully cold there in winter. ;) |
#21 | |||
Did you use the nitto's for your new PB, from memory your running 245x45 555R's. It's a shame we cant stuff more rubber under these Ba's, i've got 265x35x18 555R's going on the back of mine as soon as i kill this set of sp9ooo's. Hell the nitto's are cheaper than the dunlop's (retail anyway) so im going to run them full time. Last edited by XRQTOR; 18-05-2005 at 12:36 AM. |
#22 | |||
Turbo God
#23 | |||
