Old 27-07-2007, 06:03 PM   #1
4Lowie
XRMustang
Default Falcons, Windsor or Cleveland?
Hi guys, this maybe a dumb question but I'll ask it anyway...... Falcon V8's, are they always Cleveland or Windsor or a mix over the years?
Thanks Dave
4Lowie is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2007, 06:06 PM   #2
TEaaron
TEaaron's Avatar
Yes but Ba onwards use boss motors.
Made the switch to Cleveland with the XY's and then back to windsor with the EB's
TE cortina 14.0 @ 101mph
E32 740iL Leather, sound system, rollin' on 19's
TEaaron is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2007, 06:13 PM   #3
4Lowie
XRMustang
Thanks, so a 94 ED Fairmont, 5 Litre V8 would be a Windsor?
Old 27-07-2007, 06:15 PM   #4
Powdered Toast Man
Professional Mouse Jockey
Powdered Toast Man's Avatar
Fuel injected 5 litre is a Windsor (EB to AUIII). Pre Cleveland 302 also a Windsor.
BA uses a new Modular design similar to the 4.6 Litre Mustang engine. Actually it is based on the 5.4 Litre F-Series truck engine. Or in the case of the 5.4L 3V, is the F-Series truck engine
Isuzu MUX for towing horses - currently no Fords in the stable
Time flies like an arrow; fruit flies like a banana. Groucho Marx
Powdered Toast Man is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2007, 06:21 PM   #5
Allen
You win again, gravity!!!
Allen's Avatar
XR - 289W
XT - 302W
XW - 302W/351W (P1 HO had windsor, P2 HO had clevo)
XY - 302W/351C
XA thru XE - 302C/351C
EB thru AU - 5.0 (EFi 302W)
BA to Now - 5.4 3V/5.4 Boss
Did the XY have 302 Clevo's too? My uncle had an XYGS with a windsor, but I can't remember if they came with 302C as well...
1966 Fairlane 500 XL
Allen is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2007, 06:23 PM   #6
4Lowie
XRMustang
Thanks, I'm looking to buy all the injection gear, manifold, ecu and harnes to fit to my 302 65 Mustang that I'm twin turboing. I'm hoping I can reflash the ecu as well. Or do I get another ecu?
Old 27-07-2007, 06:28 PM   #7
Allen
Allen's Avatar
If you are going to be fitting twin turbo and EFi I wouldn't bother with a factory ECU, as they aren't well supported here, and you have to deal with things like smartlock etc...
I would go for a megasquirt system personally.
As for the manifolds, the best of the factory stuff was the "explorer" intake found only on EL2 XR8's and all AU V8's... the earlier "HO" manifolds were woeful in terms of flow.
Aftermarket manifolds are much better again... things like edelbrock or trickflow flow quite nicely.
Old 27-07-2007, 06:43 PM   #8
4Vman
4Vman's Avatar
The good ones were Cleveland! :Reverend:
335 S/C GT: The new KING of Australian made performance cars..
4Vman is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2007, 07:53 PM   #9
gs1973
gs1973's Avatar
:hihi:
gs1973 is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2007, 08:13 PM   #10
xr4_laser
xr4_laser's Avatar
we have a ZK fairlane that we put a 351 clevo in many years ago and she still thumps down the road. check it out on www.cardomain.com
Put it this way when you plant the foot it's better than botox! lol
The boss engines are sweet though : . Fords are back in the game!
xr4_laser is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2007, 08:45 PM   #11
Burnout
Falcon RTV - FG G6ET
Burnout's Avatar
The Windsor was replaced mid XW with a Clevo built in Aussie. The Clevo was made in Dearborn in two different blocks a thin wall casting and a thick wall casting used in F series trucks in the Us & Canada.
All the Aussie blocks were the thick wall arrangement and heavier, easy to make a 4 bolt main.
When Ford reintroduced the V8's in the late XD's and XE's they imported blocks from the Ford factory in Mexico. Dearborn had stopped making Clevos by then.
The Mexican block could be recognized here in those days as it was painted black, however it was of the US type thin wall casting.
Another handy thing about the thick wall castings were you could safely bore 'em out further without splitting the webs. You could also bore out the cylinders and re-sleeve 'em.
I know a lot of blokes who bored them out and re-sleeved them and they used to leave a thickness of the original sleeve in the bottom, and then pressed the new sleeve down till you hit bottom - the head then stopped the sleeve from coming out the top.
This set-up worked quite well. A lot of Aussie thick wall blocks were shipped back to the US after Dearborn closed production and were prized by the street strip builders over there......
BAII RTV - with Raptor V S/C.
RTV Power
FG G6ET 50th Anniversary in Sensation.
While the basic Ford Six was code named Barra, the Turbo version clearly deserved its very own moniker – again enter Gordon Barfield.
We asked him if the engine had actually been called “Seagull” and how that came about.
“Actually it was just call “Gull”, because I named it that. Because we knew it was going to poo on everything”.
Burnout is online now   Reply With Quote Multi-Quote with this Post
Old 27-07-2007, 08:53 PM   #12
Nostalgia
LOW AND SLOW
Nostalgia's Avatar
Amen to that. :evilsasmo
Nostalgia is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2007, 09:22 PM   #13
DJM83
Barra Turbo > V8
DJM83's Avatar
Looking through that one eye :
-2011 XR6 Turbo Ute - Lux Pack - M6
-2022 Hyundai Tucson Highlander Diesel N Line
DJM83 is online now   Reply With Quote Multi-Quote with this Post
Old 27-07-2007, 09:23 PM   #14
Gammaboy
Grinder+Welder = Race car
Gammaboy's Avatar
Bwahahahah. so far off its not funny.
"No, it will never have enough power until I can spin the wheels at the end of the straightaway in high gear"
- Too much power is never enough....Mark Donohue on the Can Am Porsche 917.
Gammaboy is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2007, 09:27 PM   #15
XAGSV8
Member 178
XAGSV8's Avatar
No it only started with the XA.
1972 XA GS Fairmont
1963 Morris Mini
1999 NU Fairlane Ghia
XAGSV8 is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2007, 09:46 PM   #16
Elks
Elks's Avatar
interstingly the parts book for xr/xy & za/zd seem to notes a 302 clevland available in zc/zd fairlane but a windsor for falcon.I musy be reading this wrong.
can anyone clarify?
Oooh baby living in Miami....
Elks is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2007, 09:59 PM   #17
Mutley
XR - 289W
XT - 302W
XY - 302W/351C
The first two production months in 1972 of the XA 302's were also windsors. The change to 302 clevelands came in April
Mutley is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2007, 10:08 PM   #18
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
Oh, so what did they build in Cleveland Ohio ?
I'll give you a clue
Falcon Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2007, 10:16 PM   #19
gazza750
token import owner
gazza750's Avatar
302 c is actually a 302 geelong 351 c was made in cleveland and windsors were made in windsor ontario
gazza750 is offline   Reply With Quote Multi-Quote with this Post
