Old 22-07-2007, 08:01 PM   #1
hanky
TF Corty
hanky's Avatar
Question Power steering question
Does anyone know what's involved in removing the power steering from a TF cortina? Can you just remove it or do you need to change the steering rack to a non power steering unit?
Thanks in advance!
"That's the way the cookie crumbles!"
http://www.aussiefords.com/categories.php?cat_id=335
hanky is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2007, 08:35 PM   #2
P100 Ute
P100 Ute's Avatar
youd need to change the rack over
is it broken or are u selling it to someone ?
theyre is loads of non power steering racks out there... its the power steering racks that are hard to find so picking up a standard rack will be very easy.
P100 Ute is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2007, 08:56 PM   #3
hanky
TF Corty
hanky's Avatar
Not broken, just not happy with the feel of it. It makes the steering too light IMO, and since It's no advantage to me might as well have 1 less thing the engine is spinning! What would happen if I didn't change the rack over? Might be a silly question but I'm curious as to what the difference is!
Cheers!
Old 23-07-2007, 12:31 AM   #4
P100 Ute
P100 Ute's Avatar
it would proberly seize on you.
power steering works on fluid been pumped around it via the motor...
if no fluid been pumped.. then no lubrication..
the standard racks have grease inside them to lubricate them..
Old 23-07-2007, 07:37 PM   #5
hanky
TF Corty
hanky's Avatar
OK! Now I see! Bit more involved than i thought, thanks for your help.
