Old 06-07-2007, 02:20 PM   #31
Rhubarb
Does anyone know what impact the Ethanol blend fuel has on LS focus?
The local servo here always has the 95 RON E10 at 2 or 3 cents less than stnd 91 RON and typically 8 to 10 cents per litre cheaper than normal 95 RON.
Now the handbook says its ok to use E10 but will use more fuel.
So the question is how much more ??? Its roughly 8% cheaper but does it use more than 8% more fuel ? (compared to stnd 95 RON)
Does anyone have any data - scientific or anecdotal, to support an opinion on this ?
Rhubarb is offline   Reply With Quote Multi-Quote with this Post
Old 06-07-2007, 02:31 PM   #32
BlackLS
Posts: n/a
I've done 2 tanks on 95RON E10 with advanced engine timing and no probs. The car is able to run on E10
Old 06-07-2007, 07:25 PM   #33
melbzetec
Old enough to know better
melbzetec's Avatar
General scientific view is that fuel efficiency drops by 2-3% for E10 compared with regular ULP
How did you calculate 8-10% cheaper? If it's 8 to 10c cheaper than 95RON, you'd need to be paying only $1 per litre to get 8-10%. If you calculate it at $1.50 a litre, you are looking at more like about 6% cheaper.
Plus some of the high octane fuels are More fuel efficient.
I couldn't be bothered frankly. I stick with BP Ultimate. The extra cents are cheap maintenance of my car I reckon
Manual 2003 Machine Silver 5 Door LR Focus Zetec.
Mods: Ford Racing CNC'd cylinder head milled .040", 3 angle valve grind. Ford Racing Stage II camshafts. Ford Racing cam gears. Ford Racing long tube header. Random Technology hi flow cat. Herrod 2.25" stainless cat-back. Pipercross Viper intake. CFM 65mm throttle body. 2000 ported intake manifold. Herrod Custom SCT tune. Eibach suspension. Quaife ATB diff. Wilwood 13" brakes. Custom ST170 leather interior.
www.cardomain.com/ride/2773918
melbzetec is offline   Reply With Quote Multi-Quote with this Post
Old 06-07-2007, 08:03 PM   #34
XR5-Boy
You mad, bro?
XR5-Boy's Avatar
yah, i agree. i was running ethanol blend in my Cougar but not now. I run standard premium in it now and it's being great. Ethanol was inefficient (only 450 to a tank!) chuck in standard premium and i get 550 now :| Depends on the car really. My old car which my sis has now (1991 TR Magna SE) runs ethanol blend no problem!
2009 LV Focus XR5 Turbo Performance Blue
SFS 2007 Best Cougar, SFS 2010/2011 Best Focus XR5
XR5-Boy is offline   Reply With Quote Multi-Quote with this Post
Old 06-07-2007, 10:22 PM   #35
Rhubarb
I live in Qld (SOO series winner .... again) and have filled up with the 95 RON E10 the last two tanks at $1.11 so nowhere near $1.50.
A 2-3% drop in fuel consumption with savings of 8% is still worth it in terms of economy, albeit insignificant in light of wife's recent spending. Focus on what I can control though hey .....
Old 06-07-2007, 11:55 PM   #36
melbzetec
melbzetec's Avatar
Yes, but when you say 8% cheaper, 8% cheaper than what? 8% cheaper than 95RON premium. So therefore you have to base it on the cost of 95RON.
And that 2-3 % drop is compared to standard ULP 91 RON. The ultra premium supposedly have a higher calorific value than standard ULP, so gives you even more kms per litre.
Your maths is a bit wonky, and you are sort of comparing apples with pineapples.
Old 07-07-2007, 09:58 PM   #37
Rhubarb
The question was ....
My maths is fine. Perhaps its my english ... or maybe your reading - who cares.
Either way, I was comparing E10 95 to stnd 95 RON.
So what represents better value?
- E10 95 Ron at $1.11/litre
OR
- Stnd 95 Ron at $1.20/litre
Old 07-07-2007, 10:11 PM   #38
More revs
Not sure how the numbers stack up but I have tried both and the E10 95 goes the same as E0 95 in mine, but the E10 is cheaper so it wins the non scientific test by more revs.
Two things I noted was standard 91 RON my Focus ran like it had my two sister inlaws in the back seat... +200 Kg. Also when I use 98 RON either ethanol or not it runs slightly better than 95 with more bottom end and about 50 Km more per tank.
Once again not a scientific test but seat of the pants (where I keep my wallet) the E10 95 wind every time.
More revs is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2007, 10:37 PM   #39
Rhubarb
Interesting.
I'm going to try 98 E10 next time but hard to make a real comparison as my mix of hwy to city varies so much, depending on where I'm working that day.
People with a more consistant driving pattern should be able to give a better comparison than me.
Old 08-07-2007, 12:15 AM   #40
melbzetec
melbzetec's Avatar
Drop the attitude. I was only trying to help. Go and save your few cents and be happy
Old 08-07-2007, 03:24 PM   #41
Rhubarb
No attitude intended. I do appreciate the assistance.
Cheers.
