Old 05-03-2007, 06:17 PM   #1
gilbertthegreat
gilbertthegreat's Avatar
Default I hit a roo the other night, and now car is revving funny.
Hey all
I hit a roo on the way home from work the other night. He hit just about the right front wheel (Futura El 97 SW Auto)
Since then, the car has been revving higher than it should. In park it revs at about 2000.
Today when I got home, and put it it park, it was reving continuously up and down from 1000 to 1500 revs, like someone was putting their foot down and then taking it off the accelerator.
My old Corolla FX GT used to do the same when it had a leaky radiator - it reacted that way when it was overheating. But the water level is fine in the Futura.
One other thing - I have LPG staright case installled, if that makes a dif.
Any idea as to what's doing this?
Shaun
http://www.pa-hire.net.au South Coast PA Hire
gilbertthegreat is offline   Reply With Quote Multi-Quote with this Post
Old 05-03-2007, 06:46 PM   #2
atec77
Originally Posted by gilbertthegreat
Hey all
Shaun
How about you disconnect the battery , stamp on the brakes wait 20 minutes then connect and try starting , get back to us if that fails
Old 06-03-2007, 06:43 PM   #3
jaydee
jaydee's Avatar
Not a bent fuel line somewhere is it and its trying to pump more gas through??
jaydee is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2007, 07:19 PM   #4
T3ts50
T3ts50's Avatar
If that was your only problem consider your self lucky.
T3ts50 is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2007, 07:28 PM   #5
Kryton
Kryton's Avatar
and whats that sposed to do?
Old 06-03-2007, 07:32 PM   #6
Deadman
Deadman's Avatar
Give you something to do for 30 mins?
Deadman is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2007, 10:21 PM   #7
Bill_R
Bill_R's Avatar
reset the ECU.
Bill_R is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2007, 11:16 PM   #8
BlackBa
BlackBa's Avatar
Knocked an air line of the motor some where.
BlackBa is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2007, 04:32 PM   #9
sheppy
sheppy's Avatar
Yeah, it's going to be a disconnected/broken vacuum hose (check around the intake) somewhere
AUIII XR8 Ute
sheppy is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2007, 12:57 PM   #10
GRNKPR
DPC PERFORMANCE Race prep
GRNKPR's Avatar
is it skipping or jumping ?????????????????????????????????????????????????? ?????
: : i will excell with the knowledge i get on here : :
FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria
Ford Performance Car ClubFord Performance Car ClubFord Performance Car ClubFord Performance Car Club
GRNKPR is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2007, 11:16 AM   #11
gilbertthegreat
Cheers Guys
I tried the battery disconnect thing, but no change.
It's not skipping or jumping, it just revs higher, almost like the auto is in too high a gear. When I'm driving, I can feel the car trying to push along harder, and when I brake, I'm fighting the engine - it's like the transmission doesn't want to let go.
When I park, and put the car in park, the engine revs up high for a second, then backs off to about 800rpm, then revs up again, then backs off and stays at 800.
I don't know a lot about cars, so aren't sure where to find the things you guys mention. I just thought you might be able to pick the problem from the symptoms, and then I won't look like such a gullible goose when I take it in to get fixed.
Any ideas?
Shaun
Old 12-03-2007, 04:38 PM   #12
sgt_doofey
sgt_doofey's Avatar
Probably just a vacuum hose loose or fallen off somewhere. I have done this a few time with my car only to realise it once I start driving it and it runs like crap. Go have a look under the bonnet for all the vacuum hoses and see if there is one that isn't connected up to something at one end.
Cheers,
Sam.
sgt_doofey is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2007, 05:42 PM   #13
FPV GT
I Like To Shake It
FPV GT's Avatar
You say you hit the roo at the right front wheel.
Check power steering for any damage, pump may be putting extra load onto engine, 100-300 rpm seesm about right but ranging over that is bizarre.
Regards
Paul
Regards
Paul
2016 S550 TY GT Coupe....some loud bits and some glass bits
I like My GT SHAKEN, and Blown
Happiness is a TY S550, a 1911 semi automatic, and the Lovey Lizzie by my side.
Originally Posted by Lovely Lizzie
whilst looking at man riding a pee wee 50
"That sure does nothing for his masculinity"
FPV GT is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2007, 06:50 PM   #14
Cobra
Bear with a sore head
Cobra's Avatar
Cobra is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2007, 08:06 PM   #15
GasoLane
Former BTIKD
GasoLane's Avatar
Didn't some cars have a vacuum tank in the wheel arch. Have a look under the arch and see if there's a small tank, could be cracked or have a cracked pipe.
Old 12-03-2007, 09:17 PM   #16
mustang70
damn you beat me to it, yeah vaccum line first check
mustang70 is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2007, 10:53 PM   #17
Also check shock didn't move the distributor or Cam angle sensor slightly and put your timing out. I hit a very large one in a mini moke once that jumped again its roo bar. In addition to a small bend in the roo bar and shock bent the shaft in my starter motor where it was attached to the ring gear. The roo jumped off to live another day.
Old 13-03-2007, 01:11 PM   #18
gilbertthegreat
Thanks for your help guys
Where can I find a manual for a 97 Furura EL SW? I have no idea what the parts are you're talking about, but reckon I could fix a basic prob if I can locate it.
Shaun
