#31 | |||
KITTY Crew Member
![]() He who breaks things can only make them stronger. ![]()
FOR SALE BAII Super Pursuit 0083 ![]() Awsome power by XTREME FORD TUNING 500rwkw New ALLOY Block Awesome exhaust by THE EXHAUST CENTRE MIDLAND Awesome Kenne Bell Supercharger setup by AGRO! and Bluepower Racing Developments Now with full DOT approval and Permitted for road use
#32 | |||
I remember a few runs i had ages ago I was trying to change that fast from 2nd to 3rd i grinded it through without the clutch, on the return road I was almost feeling sorry for it! lol Before there were short shifters in the 3650's the 2-3 shift was a hit and miss affair, a cause of much %&$@!'s in the cabin! |
#33 | ||
My kids think I'm cool
Johnno- i have to say in all honesty after both driving your car and watching the few runs on Wednesday that it is capable of a 12 with ease.
Firstly, AFAIK the MT's need a bit of a burnout to get the heat in them up- while I could see the officials there seemed to be rushing everyone through, I think getting more heat into those tyres is critical to their effectivness. If you don't want to do a longer burnout or it is an issue (too hard on the car etc) I would look at the Toyo RA-1 for your own set- Simon ran those on his wife's Xr6T and remarked (along with many reviewers) about how quick they got heat up and how sticky they were- they are certainly the ones I'll be getting and around $480 each for 18" if you want to stay at 18" for some reason. Listening to it and looking at your graph maybe short shifting to second would allow the torque to pull alot harder- I know with my T3 if I short shift second the car just digs in so hard and gets the power down, it isn't hard to get it to break out by letting it rev a bit more but every point of a second the tires are spinning you're not covering ground The 60' is definately where it is for you mate as you've openly suggested- I would ride that clutch out of the whole at 5,000rpm- you've got the good gear there to take it and it seems that's how the best times are done, maybe it's better on the car too, i don't know It looks and sounds stunning on the track mate and you are certainly capable of getting a stout time to back it up- if what you're doing isn't working you will need to try something else........... "You can do it!"
2011 FPV GT 335 >My Build Thread< (Posts 3511-3515 has a compilation of most of the pics, page 118 @ 30 posts per page) BLUESTREAK built 5.2L flat-plane-crank VOODOO with 3.2L Intercooled Kenne Bell blower, 1000rwhp/746rwkw @ 8000rpm @ 20psi on E85. Built ZF with BLUESTREAK 2C Circle D converter. Unbloodybelievable... 2018 Ford Ranger RAPTOR 2013 Audi SQ5 |
#34 | ||
Yes as above soft compound tyres will need more heat to get grip, if they are used without heat they will be worse than street tyres. How long has your burnout been so far?
You have the 4.11's and plenty of grunt, give it heaps in the burnout box and do the burnout in 2nd and get plenty of smoke. 2nd gear will allow you to get the temp up in the rubber quicker without getting the engine hot too quick |
#35 | ||
trying to get a leg over
![]() Join Date: Dec 2004
I was using 17" M/T ET Streets on mine a while ago before i went full slicks and front runners, and i found tyre pressure anywhere between 16psi to 20psi to be good, depending on the track and temperature.
Get plenty of heat in them on your burnout, but be sure to check them after each run as they can increase by about 2psi after every run.
Cameron ------------------------------------------------------ |
#36 | |||
Now a FG XR8 in Nitro
Nitro XR8 6 Speed Manual - SS Inductions Growler, Herrod Headers John Bowe exhaust 0-60kph 2.46 secs |
#37 | ||
strong burn untill you start to feel the tyres grip up and be more brutal coming out of the hole side step it at around 3500 - 3800
#38 | ||
Thats right baby X-rated
Sorry to steal the thread for a second but....
After having a bit of a go at Whoop A s s Wednesday last year in my ute , i am keen to give it a bit more of a go(now I got the new clutch in the big orange girl). I ran a best time of 14.84(slow aint it) with a terminal speed of I think about 98mph. The biggest problem i was having was getting off the line. If i tried to launch my ute with anything above two grand it just lit up. I was thinking that if i had a bigger sidewall profile than the std 235/45-17 that i might be able to get a bit more sidewall flex and get a bit more of a bite on the track. I have trial fitted some territory tires on my rims and fitted them to the ute with no problems so thats what i was going to have a crack with. I guess what i'm asking for is opinions on weather this will work for me or if anyone else has tried this. i wouldn't mind getting some advice on tyre pressures too. Cheers Travis (another dude addicted to drag the good kind of drag)!!! Ha ha. ![]()
If Im going to hell ![]() RIP The Gentleman, Peter Brock 1945-2006 ![]() I cant believe they demolished that fatefull tree!!! |
#39 | ||
KITTY Crew Member
Hi Travis, all I can say is give it a go.
We have another proutes drag night this Wednesday, so come on down. Just ask the scrutineers to put the pro-utes lane number on your window
#40 | ||
Superpursuit83 I also recomend Toyo RA1s, for a street/drag radial tyre, they are what I use on the Capri and do low 1.6 sixty foot times with 11.65 ETs. Talk to Mark at Bayswater Tyres.
#41 | |||
AFF.com.au
Your car can go an average 2mph faster with a change of header. Chris |
#42 | |||
Too many variables to compare, i think i am the only pacemaker car into the 11's NA ??? Every other car has been running De fillipo, we will try and smash my 11.89 next time out, no doubt it will if the conditions are good.
#43 | |||
KenneBell Australia
Bluepower Racing Developments Proud Australian Distributors of Kenne Bell superchargers The Quickest, The Fastest, The Baddest Boss Blower of all. www.bluepower.com.au |
