19-02-2007, 02:45 AM | #1 | ||
hey guys i just brought a ts50 bodykit i got it painted. about the fitting should i do it myself or should i get a pro to do it. if i was to do it myslef are there any instructions or mannuals. plaese advise :
19-02-2007, 10:20 AM | #2 | ||
The Mod Bug Has Hit
I fitted one myself but i fitted it up before it was painted because not all bodykits fitup like a glove first up you got to play around with the brackets and you are liable to scratch the kit.
Good Luck Jake |
19-02-2007, 12:02 PM | #3 | ||
Spin 'em Habib !
Pay that bit extra and get a Professional to do it ,
AU2PWR |
19-02-2007, 12:44 PM | #4 | ||
man if the kit is fibreglass you definately should have test fitted it. 8 times out of 10 it won't be a perfect fit
19-02-2007, 09:33 PM | #5 | ||
BA Xr8
Should be right to fit yourself, just make sure you have plenty of glue, sellotape, and staples.
In reality - check the fit yourself but probably get pro's to fit it. Mouldings used for making kits can loose shape with time and usuage and this alters the fit. Likewise your car may not be perfect, e.g. side doors may sag a little causing clearence problems over the side skirts when opening/closing doors. |
19-02-2007, 09:37 PM | #6 | |||
Spin 'em Habib !
AU2PWR |
19-02-2007, 09:45 PM | #7 | ||
Just cruisin
im giving mine a go by myself. Its only the side skirts im worried about because i'll need to drill holes in metal and need to make sure they're perfect. Also buddy make sure to smooth down the inside edges before you test fit.
___________________ BA LTD 5.4 |
19-02-2007, 09:51 PM | #8 | ||
DJR TM#54
Location: on my p.c now with internet! ok i'll still use works internet too.
One tip if your think of putting the kit on your self, get a friend to help you fit it.
When traveling to V8 Supercar rounds, i book through KYLEE MOLE Travel agents, She Goes, She Goes, She Goes & I just went. Now Zetec Powered. 1.6lt of madness. But the XR8 still remains |
20-02-2007, 12:25 AM | #9 | ||
Extreme_Custom
Just make sure you do have someone to help you.
and you would probably need to screw in the rear bar from inside the boot aswell ! just the sides though either left or right, depending on the kit. From personal experience you would need someone help that knows what they doing, if you crack it would cost you bit to get it fixed back. good lucks if you need professional hand drop me a PM if your in vic.
If You Think AU Are Ugly ! Check my X Out......... Loved by one ... Admired by many ... Envied by most ! RIP - F6 |
23-02-2007, 01:36 AM | #10 | ||
hey thanks for the advise people but i think that i will have to get it done professionally
24-02-2007, 02:20 AM | #11 | ||
Extreme_Custom
great way to go about it... dont forget to post pics when its done
cheers
07-03-2007, 02:02 PM | #12 | ||
hey guys my car has been sent on monday to get the kit put on should not be long now they say on thursday i should get it back ill post some pics when i get it back
