WHAP!!! POW!!! ZORK!!!
Hi there,
Has anyone got a document on how to run the diagnostics on the ABS system in a Series 1 Fairmont V8? also what the codes mean as well. I tried looking for a technical doc on AU falcon homepage but nothing, Fordmods has a really good one for every model bar the AU! The light is intermittant so I would like to sort this out ASAP in case it get's worse. Cheers all.
CAR: 99 Fairmont,Silver Engine: 5.0L,Tickford intake,extractors,exhaust. Suspension: Koni adjustables lowered. Bodykit: Havoc Wheels:XR8 AUII 17's Interior: upgraded to Ghia,rebolstered seats. Have parts just need fitting: Territory front brakes, Police issue rear brakes,Full sound system,Alpine HU/Processors,Focal speakers,Xtant amps. |
No-one able to help?
![]() Join Date: Jan 2005
Apparently not. I would try replacing the fuse, and if that doesn't work, clean the ABS sensor pickups at the back of the hubs (front) and rear wheels.
If nothing still, then go to a Mechanic/Ford and ask them to plug in the scantool and read the codes. Should be no/minimal charge for this.
The Hammer: FG GTE | 376rwkw | 1/4 mile 11.793 @ 119.75mph 1.733 60' (4408lb) 1 of 60 FG MK1 335 GTEs (1 of 118 FG Mk 1 & 2 335 GTEs). Mods: Tune, HSD/ShockWorks, black GT335 19” staggered replicas with 245 & 275/35/19 Michelin Pilot sport 5s Daily: BF2 Fairmont Ghia I6 ZF, machine face GT335 19” staggered Replicas with 245s and 275s, Bilsteins & Kings FPV 335 build stats: <click here> Ford Performance Club ACT Last edited by JC; 29-11-2006 at 03:40 PM. |
Cheers JC,
Will try that this weekend.
No worries. I would replace the fuse even if the current looks fine. An intermittant problem like this could be a loose connection in the fuse, or bad sensor readings. It could also be one of about a dozen other things, but these are the only 2 I know how to check/fix without the diagnosis from a scantool.
