Old 31-03-2005, 01:39 AM   #1
Teki04
Clio 182 CUP!
Teki04's Avatar
Default ENGINE DEBATE! 85kW or 74kW?... THE ANSWER!
OK, after talks about which stats to go by, the Log Book or the Manual... i think i have the answer.
NOW, the 74kW is the 1.6L duratec currently found in our car here and in the UK. It is a 4 cylinders in line; DOHC; 16 valves; alloy cylinder head and block; electronic multipoint fuel injection; electronic throttle engine, as stated in the Owner's Manual. This is the same engine also found in the NEW focus (in UK). Now, the 85kW is the 1.6 Duratec Ti-VCT, which is also found in the new focus (Here and the UK), but im most certain is NOT the engine found in the Fiesta. It is a 4 cylinders in line; DOHC; 16 valves; Twin Independent Variable Camshaft Timing (Ti-VCT); alloy cylinder head and block; electronic multipoint fuel injection; electronic throttle engine with about 5Nm more torque, but 11kW more.
So, according to sources here and in the UK, we have the 74kW engine, which has posted 0-100 times of 10.4 here, and 0-60mph of 9.9 in UK... looks like the model update for the Fiesta might get the 85kW engine.... DAMNIT
Steven
'In fact, so good is the Clio 182 with the Cup chassis set-up that I feel moved to make a bold statement - I think it's the best hot hatch ever built.' (EVO Jan 04)
Teki04 is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2005, 04:46 PM   #2
Pieoter
I wonder how many components the two engines share. By the look of my dyno I would say it uses more aggressive cams as these ones run out of ruff above 4000rpm and level off power.
COLORADO RED FIESTA ZETEC
MODS - Window Tint, Bmc Panel Filter, Euro Plates, Ghia grill, Momo F16 leather gearknob, Momo Leather gearboot, WQ Zetec Front sway bar, WQ Zetec Sway bar links, WQ Zetec bushes.
ICE - Alpine CDA9827, MbQuart Reference 6.5inch splits, MbQuart Reference rears, Rockford Fosgate Punch Stage 3 12inch Sub, Rockford Fosgate P4004 + P3001.
Pieoter is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2005, 08:20 PM   #3
zetec
Zoom Zoom
zetec's Avatar
CORRECT
The Fiesta here gets the non variable 74kw engine (when run on Premium fuel) Duratec, we don't have the VCT engine.
As for new Focus, we get the 2.0 Duratec HE engine, the 107kw version. or 145 HP
2012 Mazda3 MPS
