Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Furious Performance
Furious Performance Specialists in Automatic Transmission & Fluid Transfer Products Website Link
Old 22-06-2014, 11:15 AM   #1
Furious_8
Sponsor
Default Ford PX Ranger 6R60 Oil Cooler Port Adapters
EDIT/UPDATE 2/12/2014
Hello,
Furious Performance is proud to announce the release of our new 6R80 transmission cooler port adapters. These fittings allow the removal of the factory Heat Exchanger unit mounted to the side of the transmission. With a male -8AN thread to allow easy installation with Speedflow Hose & Fittings & a simple push in male fitting to suit the transmission housing. The fitting are sold as a kit and also include a stainless steel bracket.
Ford/Mazda/ZF 6 Speed 6R80 Automatic Transmission found in the following vehicles.
Ford Ranger 2011 – Present
Mazda BT-50 Second Generation 2011 – Present
Ford Territory SZ V6 Diesel 2011 – Present (May fit petrol but case and sump must has Ford logos not ZF)
Sold as a Kit and Includes: 2 x 922-6R-08-BLK fittings + 1 x Stainless Steel Bracket
Part Number: TCK-06RKIT
Purchased from our website
-8AN Male Flare 90 Degree Ford 6R80 Case Adapter Kit - Click Here
"To be used with AN style hose end fittings and braided hose also Available on our site"
1/2" Barb Adapters to suit - Click Here
"To be used with 1/2" ID ATF Rubber hose and requires a clamp"
1/2" ID Automatic Transmission Fluid Hose - Click Here
1/2" Barb PWR Extra Large Transmission Cooler - Click Here
Please Note:
If you have bought our ZF Falcon/Territory fittings and have not used them we are happy to return them please contact us via email sales@furiousperformance.com.au
Furious_8 is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2014, 12:51 PM   #2
EFIwindsor
Haltech 302w XW
EFIwindsor's Avatar
Default Re: Ford PX Ranger 6R60 Oil Cooler Port Adapters
I would like to put an aftermarket cooler onto my 2012 BT50 -
Is the thermostat for the transmission internal to the gear box or will adding an external cooler remove the thermostat from the circuit?
Thanks
Ben
1969 XW Fairmont-1999 explorer 5.0- comp cam XE270HR, 9.8:1comp, Ported Gt40p, Ford Racing oil Cooler, EL V8 radiator & thermo's,
Fuel/intake -XR6T injectors, 255 LPH intank pump, 4" intake, HaltechE11v2 Exhaust-custom Tri-Y headers, Twin 2.5" HiFlo Cats, duel 2.5" exh Driveline-close ratio 4spd, 9" LSD, 300mm AU XR8 fr, XC rear, ZH Fairlane Mas/Cyl & Booster
Project car: http://www.fordforums.com.au/showthread.php?t=21641
EFIwindsor is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2014, 03:56 PM   #3
Furious_8
Sponsor
I have not seen under a bt50 but it should be very similar to the ranger if it has a 6r60 box in it. But being a mazda it could have somthing else. The problem people seem to be having with the ranger is the converter over heats. The cooler return enters the converter first so going to a external cooler can help reduce heat and save the converter. Im looking to do tests on some vehicles soon but as they are still under warranty there is not much of a call for a complete kit yet.
As for the thermostat in the cooling line im not sure if it can be removed I would need to look at one again.
Cheers Rhys
Old 10-07-2014, 10:52 AM   #4
EFIwindsor
Haltech 302w XW
EFIwindsor's Avatar
Thanks for the reply,
My is out of Warranty in 12 months so I too will be looking to do something then.
BT50 has same driveline as Ranger. All parts even have the FOMOCO sticker on it.
I also though about seeing if this pan would fit http://www.yourcovers.com/transpan_11089.php
Old 02-12-2014, 08:43 PM   #5
simon varley
Technical Contributor: For members who share their technical expertise. - Issue reason: Bringing sanity to the Everest threads.
Ranger and BT50 are identical in terms of powerpack. The oil control valve for both is internal to the transmission
simon varley is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2014, 08:46 PM   #6
Furious_8
Sponsor
These are now available on our website
Old 02-12-2014, 08:53 PM   #7
Furious_8
Sponsor
Cheers Rhys
I have confirmed there is know known external or internal thermostat with these transmissions here in Australia.
The Vehicles i have tested flow the same oil from cold to 60 degrees and is very similar to the ZF6HP26 in the Falcons/Territory's.
Rhys
Old 15-12-2014, 02:47 PM   #8
EFIwindsor
Haltech 302w XW
EFIwindsor's Avatar
Thanks.
Do you have a kit to suit this vehicle? or Should I just buy parts and make my own brackets?
Old 16-12-2014, 11:37 PM   #9
Furious_8
Sponsor
The main problem is getting a vehicle for the time needed all the customers i have are all trades and need the vehicles. Also trying to have a kit to suit both ranger and bt-50 has also caused delays as i almost need both at the same time.
Old 19-12-2014, 12:23 PM   #10
EFIwindsor
Haltech 302w XW
EFIwindsor's Avatar
Sorry I cannot help as I am in Brisvagas - A little to far to drop off for a few days.
Old 18-04-2015, 04:21 PM   #11
EFIwindsor
Haltech 302w XW
EFIwindsor's Avatar
Are you any closer to a kit?
Old 04-05-2015, 06:04 PM   #12
GOF
GOF's Avatar
I made my own brackets and adaptors and added an external trans filter and replaced the coolant hoses with the manual EGR hose.
GOF is offline   Reply With Quote Multi-Quote with this Post
Old 04-05-2015, 06:51 PM   #13
EFIwindsor
Haltech 302w XW
EFIwindsor's Avatar
What size however did you run? 3/8 or 1/2"
Old 04-05-2015, 08:09 PM   #14
GOF
GOF's Avatar
3/8, if you use 1/2 things will get very tight trying to find a route for them to the front.
I ran them under the starter solenoid, over the filter (so they don't have an oil bath with each service and start to rot) and engine mount then one tied to the A/C pipe past the radiator(s) to the cooler, the other one around the outside of the body mount and down to the filter mounted on the chassis cross member and then back up to the cooler.
So far it takes about 10 km to warm up and sits on 90-95 from then on.
In three weeks I'm heading north with the van so it will get a good workout and we'll find out if it realy needs 1/2 pipes.
I monitor temperatures with a Scangauge II.
Old 04-05-2015, 09:23 PM   #15
EFIwindsor
Haltech 302w XW
EFIwindsor's Avatar
I am pretty sure wholesale automatics use 3/8" as they run a factory 100series landcruiser cooler. I am sure with their experience they would be all over hose size and flow.
I only asked as the furious performance one are 1/2"
Old 05-05-2015, 09:10 AM   #16
Furious_8
Sponsor
I have a few customers using 3/8" with out any problems after all all the ZF kits i sell are mostly 3/8" and work well.
Old 16-09-2015, 10:04 AM   #17
EFIwindsor
Haltech 302w XW
EFIwindsor's Avatar
How did your trip go? Did the cooler make a difference?
Old 15-10-2015, 04:58 PM   #18
GOF
GOF's Avatar
Using a Scangauge II to measure the temp it sat on 88 to 92 except one 35 deg day it hit 93.
You can actually see the thermostat working with the temperature rapidly climbing to 80 deg and then very slowly until it reached equilibrium. With nothing on the back it takes about 10 km and around town sits on 82 to 85 deg.
Old 04-06-2016, 12:57 PM   #19
mexicov
Does the 6R60 transmission suffer the same "milkshake" problems that ZF 6HP26 transmissions in FG Falcons have, where corrosion of the oil/water transmission heat exchanger can let water into the transmission, wreck the mechatronic computer and cause in excess of $5000 damage? Thanks.
mexicov is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2016, 03:25 PM   #20
Top_Ghia
Technical Contributor: For members who share their technical expertise. - Issue reason: has been consistently providing good technical advice etc. to AFF members, by having the vast technical knowledge he has with the various Ford products. A valuable AFF member
These cars/trans have been out for years and I'm yet to see one fail due to coolant contamination.
Top_Ghia is offline   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
