#31 | ||||
Back to Le Frenchy
#32 | |||
around the place
Sometimes your best not knowing whats in the filter and drive it till it drops because end of the day, if metals gone round the motor its still going to cost you the same amount to fix it..... And if you use a purolator filter, you can spend the extra $290 on fixing the engine at some stage later on. Also just a word of warning, I've come across K&N filters that had metal filings on them out of the box, seems they dont put too much effort into quality control at the K&N factory, hence im now using pure one filters.
GPS Tracker for your vehicle - PM me for info |
#33 | ||||
Back to Le Frenchy
#34 | ||
around the place
How often are you going to check / clean the filter, daily?
If you check it once per service (5000 or 1000km), and find metal, then chances are the damage is already done to the cam / bearings / oil pump etc (we're talking road cars here, not drag cars, where in that case, yeah you could do it once per meet)
#35 | ||||
Back to Le Frenchy
#36 | ||
instead of using z9 oil filters use z89a they are shorter hence you will get better oil pressure.
#37 | ||||
Back to Le Frenchy
#38 | |||
not here much anymore
2024 F150 XLT
#39 | ||||
Back to Le Frenchy
