Old 13-11-2015, 09:00 PM   #31
Mechan1k
Mechan1k's Avatar
Default Re: The Nitty Gritty FG to FG-X what's changed?
Originally Posted by kypez View Post
cant be any worse than the milkshake issue in the German made box...
That's a poor cheap heat exchanger issue ... not caused by the transmission itself ... under the impression the same poor design heat exchanger is still in use though.
Old 16-11-2015, 08:24 AM   #32
kypez
kypez's Avatar
Originally Posted by prydey View Post
not sure what that has to do with the actual gearbox!
I'm just saying that ZF probably gave the specifications of what type of transmission cooler needed to be used and that it's falling causing the gearbox to fail is a design issue.
My comment is Just cause it is built in China doesn't mean it's going to be any less quality. With everything going to China, India, etc, I'm sure they will produce good quality goods.
For every job, there are 1000 people waiting in line. Stuff ups will be far less tolerated (parent company would come down on them pretty hard).
My Ford Family...
2014 GT-F, Manual, Kinetic with Black Stripes
2021 Mustang Mach 1, Manual, Velocity Blue
kypez is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2015, 09:10 AM   #33
mcnews
Trev
mcnews's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Trev has owned several boosted fords and has really contributed a lot of info on them. His posts in the bike section are also very helpful. I think he should be recognised as a technical contributor.
Funnily enough when I changed the heat exchanger many moons ago in my BF F6 to a larger BF R-Spec unit it was branded KTM, as in the cooler subsidiary of Austrian motorcycle manufacturer KTM.
Trev
(FPV FG II GT-E thus the fully loaded burger with the lot as standard +Alpine/Dynamat fitout - 2 of only 4 ever made GT-E factory 9" rear rims - Michelin Pilot Supersports - Shockworks Suspension)
mcnews is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2016, 04:08 PM   #34
M&Ms
M&Ms's Avatar
Old thread I know, but a few details I notice in my FGX compared to my old 09 FG:
Digital speedo unit has gone SI, now in km/h instead of km/hr
Little green cruise control light when cruise is active
Radio Station / Audio Detail no longer an option to show in the Cluster centre screen
Cruise control set speed flashes when you accelerate above set speed
Cruise set speed takes over screen when being set
Climate details on cluster centre screen (on / off / mode)
Unable to turn off feature where radio plays until door is open (after turning off car)
Unable to switch off camera when lag option is selected and in drive, unless putting in park or exceeding 12km/h
No more sun glasses holder
Sun visors are vinyl vs. Suede in my old FPV
Bottom of door trims and kick panels are plastic vs. Suede in old FPV
Audio sound quality is better than FG, more bass out of sub, but volume doesn't go high enough, especially for the digital radio
My Resume:
Current:
Alfa Romeo Giulia Quadrifoglio in Vulcano Black
MY18 Black WRX STi Spec-R
Previous:
'16 White FGX XR8
'09 Black FG FPV GT 5th Anniversary
'04 Blueprint BA XR8
'97 Mocha Foam EL Fairmont
M&Ms is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2016, 04:20 PM   #35
asagaai
asagaai's Avatar
Originally Posted by Eaturbo View Post
Don't they notify emergency services if the car is in a severe crash and air bags are deployed
Yes- and from first hand experience can tell you that it works. Pretty weird- after just having a major hit and after all the energy is dissipated and you come to a stop- sitting there in shock to suddenly have emergency services call you through the radio...and they knowing where you are and then drilling you for information- injuries- traffic dangers etc etc.
I can imagine if you were by yourself in a serious accident somewhere remote and trapped- this would be a major major peace of mind to you.
Ford get top marks for this - do all FGX cars get it?
Ford Rides:
Ford Fiesta ST Mk 8 -daily- closest thing to a go kart on road for under 50K
FG X XR8 smoke manual - Miami hand built masterpiece by David Winter, BMC Filter, JLT Oil separators, Street Fighter Intercooler Stage 2, crushed ball, running 15% E85 and 85% 98- weekender
asagaai is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2016, 08:15 AM   #36
ozpacman
First I've heard of this one.
How do "Emergency Services" manage to call you when your car isn't fitted with two-way radio?
ozpacman is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2016, 08:43 AM   #37
Giant Cranium
VF2 SSV WAGON
Giant Cranium's Avatar
it works with your phone if you have it synced
Giant Cranium is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2016, 08:49 AM   #38
Mechan1k
Mechan1k's Avatar
And SYNC actually does the dial out ... and provides the location of the vehicle from the Navigation system. Also when it notifies the emergency services it has an automated message it tells them.
It's all in the SYNC 2 information pack provided with the vehicle.
This is the same for SZII Territory models.
As MR Cranium above mentioned ... must have phone Synced .... also also ... must have emergency assistance turned on as well (as you can disable it if you wish)
Old 13-12-2016, 11:37 AM   #39
Dash_XR
Dash_XR's Avatar
Power steering pump.
FG XR6 Turbo (Manual) - 301rwkws @ 15psi
Rapid Systems Intercooler & Battery Relocation - ID 1000 Injectors - Process West Surge Tank - Venom 100 Cell Bolt On Cat - XForce 3.5 inch Catback - Plazmaman 4 inch Turboside Intake - Crow HD Valve Springs - Glowshift Gauges (Oil temp, Oil Pressure, Boost, Volt) - Malwood Opt 5 - XR50 Interior - FG2 Limited Ed 19's - Nitto Invo's
Dash_XR is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2016, 01:03 PM   #40
FoxtrotGolfXray 5.0
FoxtrotGolfXray 5.0's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Willingly providing technical info and documents, despite glitches.
Just to add a bit more information to the discussion on the Emergency Assistance function, the paired phone is used to call 000 when the car detects that an airbag is deployed or the fuel shut off valve is actuated.
A very handy feature and one that sounds like it actually works well in a real world situation thanks to asagaai's experiments
Labels are for jars, not for people.
Life is a journey, not a destination.
Daily: 2013 FGII EcoLPi in Winter White
Play: 2015 FG X XR8 in Emperor Show' N Shine thread
Gone, but not forgotten: 2015 SZII petrol Titanium Territory in Emperor
FoxtrotGolfXray 5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2016, 06:19 PM   #41
Bolly47
The new one with the girl in the blue dress (yes she is back) even has a Falcon in it OMG[/QUOTE]
Who is she ? What her name and i don't like the way she walk look stupid.
Bolly47 is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2016, 06:22 PM   #42
Trump
bitch lasagne
Trump's Avatar
I've got such a headache...
Scaled Business Solutions
For Your Small Business IT Needs
Trump is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2016, 10:40 PM   #43
commodorenutt
commodorenutt's Avatar
Poor grammar does the same, but anyway, the answer is in post 28 in this thread:
http://fordforums.com.au/showthread....56#post5647956
commodorenutt is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2016, 06:47 AM   #44
FTE217
T3/Sprint8
FTE217's Avatar
I have no time fecking around with sync 2 - hardly touched it since the salesmen showed me how to this and that - I have more enjoyment from the drive and sound that's what I'm synced to
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
"Don't believe everything you read on the internet. Abraham Lincoln"
FTE217 is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2016, 08:20 AM   #45
duaned
duaned's Avatar
Originally Posted by FGX335 View Post
The dash trims are revised,
Yes but they still insist in installing an airbag cover on the passenger side that doesn't line up with the dash, still!
duaned is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2016, 08:37 AM   #46
commodorenutt
If you look at the way the corner is angled/rounded off, you can see it's deliberate.
Probably easier in the production environment to have something deliberately misaligned (where the variation in position from car to car is less noticeable, compared to having something aligned, where a 0.2mm variance will stand out like male canine genitals.
Using the chamfered & overlapping edges is also a clever trick to hide the fact that production tolerances can't be tight enough for a perfect fit on every occasion too.
The console sides, console insert, ICC, ICC cover, dash spears and many more parts all use this to great effect. The VE Commodore dash also uses this concept extensively. It's very hard to pick a misalignment when you have 2 chamfered surfaces meeting (like the FG console side trims) compared to flat items.
Old 14-12-2016, 11:59 AM   #47
mcnews
Trev
mcnews's Avatar
Originally Posted by Adrenaline View Post
Foam support behind the front bar now, replaces that annoying eggcrate looking crap in FG. Revised wiper blades (although I believe some very late FGII builds received them too).
The wiper arms are cheap as, next time you need new wiper blades on your FG just get the whole FG-X arms from a Ford dealer, they are pretty cheap too.
Trev
Old 14-12-2016, 12:32 PM   #48
kypez
kypez's Avatar
You dont need to change the arms of FG to use the FGX blades. They just clip on the existing arm. I'm using the FGX blades from Ford for the GTF and the G6E. Work a treat.
I like them better than some of the aftermarket ones as they are more flush in the way they mount
My Ford Family...
Old 15-12-2016, 08:52 AM   #49
mcnews
Trev
mcnews's Avatar
The arms are better too though on the FG-X and don't lift off the screen like the BF and FG ones do etc.
Trev
Old 15-12-2016, 09:50 AM   #50
the_scotsman
MY21.5 Mustang GT
the_scotsman's Avatar
Could have sworn this is an option in my FGX G6ET. it's in the dash settings from memory.
Old 27-12-2016, 11:13 PM   #51
M&Ms
M&Ms's Avatar
Another feature that has disappeared between FG and FGX is the ability to adjust the sensitivity of the auto/on and auto/off of the automatic headlights (not that the settings made much of a difference anyway, but still a nitty gritty)
My Resume:
Current:
Previous:
'16 White FGX XR8
Old 28-12-2016, 12:45 AM   #52
kypez
kypez's Avatar
How do you do that? By FG, do you mean FG 1? I can't see that setting in FG2
Sent from my Pixel XL using Tapatalk
My Ford Family...
Old 28-12-2016, 01:58 AM   #53
M&Ms
M&Ms's Avatar
Yeah my FG1 had it, could be found in the ICC settings. Don't know about FG2, only ever driven one as a hire car, but definitely non-existent on my FGX
My Resume:
Current:
Previous:
'16 White FGX XR8
