Old 09-06-2014, 10:41 PM   #31
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Default Re: what has more potential for power?
Originally Posted by HULK_I6T View Post
Why not a huge 4000cc 4 cylinder with vtec?
Discussion not limited to other types of designs. Just looking at a certain displacement and considering the options.. Let's say 4000cc
Cummins 4BT, 3.9L 4 cylinder lol.
Old 09-06-2014, 10:44 PM   #32
Nikked
Oo\===/oO
Nikked's Avatar
Could having more cylinders have an advantage in rotating mass? Smaller piston size, and lighter...more free revving?
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2014, 10:26 AM   #33
mik
mik's Avatar
Originally Posted by FPV GTHO View Post
Why would an I6 use less fuel, everything else equal?
Less friction, less cranking pressures.
Old 10-06-2014, 12:31 PM   #34
Bent8
Long live the GT !
Bent8's Avatar
Originally Posted by dragons90 View Post
Also look at the GT3 RS 4.0 368 kW at 8250 rpm and 460 N·m of torque at 5750 rpm
Good point but I'm guessing the Porsche motor has a more aggressive cam because the BMW V8 reaches peak torque at just 3900rpm..
2018 Ford Mustang GT - Oxford White | Auto | Herrod Tune | K&N Filter | StreetFighter Oil Separators | H&R Springs | Whiteline Vertical Links | Ceramic Protection | Tint
"Whatya think of me car, XR Falcon, 351 Blown Cleveland running Motec injection and runnin' on methanol... goes pretty hard too, got heaps of torque for chucking burnouts, IT'S UNREAL !!" - Poida
Bent8 is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2014, 01:32 PM   #35
Vesper Martini
Vesper Martini's Avatar
A large capacity 4 cyl will have a Huge Bore and stroke will result in a low revving engine with lots of Torque.
wouldn't be very smooth either
not really suited for Hondas V-Tec
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2014, 05:08 PM   #36
Nikked
Oo\===/oO
Nikked's Avatar
Or cars, for that matter...
\≡≡T≡≡/
Old 11-06-2014, 05:15 AM   #37
Crazy Dazz
There are some problems with large 4 cylinder engines. Not really sure, but I think it has something to do with the mass of the moving components (pistons, rods, and crack) increasing relative to the mass of the block. (They're balanced vertically but not horizontally?) That's why in the past engines much bigger than 2 litres had balance shafts.
With modern engines it seems 2.4~2.5 is ok, and diesels upwards of 3 litres.
I think straight 6's and V8's are better balanced in all axis.
The reality is that if the bore & stroke are similar, you're going to have similar potential. As somebody said, how long is a piece of string. It really is a question of packaging. In the past I reckon that under any given bonnet, you could get better induction and exhaust with the angled cylinders of the V8. Not so sure that still applies with EFI and forced induction.
Old 11-06-2014, 09:30 AM   #38
Vesper Martini
Bore & Stroke x number of cylinders essentially set the engine capacity.
http://www.dartheads.com/engine-calculators/
so they cannot be similar
Old 11-06-2014, 09:38 AM   #39
Vesper Martini
I would say yes, where as the lesser cylinder engine could potentially produce more Torque.
Old 11-06-2014, 11:43 AM   #40
_Ben
_Ben's Avatar
If you guys want to play around with this, check out Automation Game. Pretty rad little game, you can make various engines (inline 4/6 and v8s), change bore / stroke / materials / head type etc, gives very close to real life outputs
_Ben is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2014, 05:15 PM   #41
ebxr8240
Performance moderator
ebxr8240's Avatar
The budget would be higher on V8 .. Well ?? The $$ I have invested in a turbo IUZ compared to many SOHC Ford 6's .. Is two fold ..
The strange part is the stroke of the Ford 6 and of the Toyota V8 being 3.25 is longer than the Windsor 5.0 which is 3" yet the IUZ revs higher ..
Daily driver GTE FG..
Old 11-06-2014, 08:07 PM   #42
Crazy Dazz
So a one cylinder engine will be 12 times more powerful than a V12 of the same capacity???
Old 11-06-2014, 08:40 PM   #43
FPV GTHO
Technical Contributor: For members who share their technical expertise. - Issue reason: Sharing his knowledge of performance exhaust setups for the NA 6 cyc Barra Falcon from BA to FG.
V8's aren't so much better balanced, just easily balanced. If you want a naturally.balanced motor it's still I6, V12 and boxers to look out for.
FPV GTHO is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2014, 01:37 AM   #44
Vincenzo
Vincenzo's Avatar
Just to throw the cat among the pigeons - I was under the impression that the 5cyl engine was the smoothest - ala Audi Quattro Group B with sufficient power and an engine sound to rival any V8
Cheers Vincenzo
$DO || ! $DO : try
try: command not found - (YODA the Geek)
"WRC is for boys, Group B was for men" - Juha Kankkunen 4 times World Rally Champion
Romanes Eunt Domus - 'people called Romanes they go the house' - You mean Romani Ite Domum
[SIGPIC][/SIGPIC]
Vincenzo is offline   Reply With Quote Multi-Quote with this Post
