Old 12-01-2015, 06:28 PM   #1
HI PSI
Default Earls vs Speedflow??
I need to order some 200 series fittings.for my Teflon braided lines. What difference if any, is there between Earls and Speedflow fittings and where is the best (and cheapest) place to buy them from??
Brad
HI PSI is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2015, 11:25 PM   #2
noosacuda
noosacuda's Avatar
Default Re: Earls vs Speedflow??
No difference in quality, but i order a mixture of brands of AN fittings from Summit Racing, too expensive to buy in Oz.
noosacuda is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2015, 11:44 PM   #3
1970galaxie
Fat 460
1970galaxie's Avatar
Speedflow are Australian, so no point going to Summit for them.
1963 1/2 Galaxie Fastback. Rangoon Red. 427/4 speed.
1970 Galaxie Sportsroof. Matt black/purple scallops. 460/C6.
1972 XA GT Sedan. Monza Red. 351C/4 speed.
2003 BA XR8 Ute. Blood Orange. 5.4/5 speed.
2006 Territory Turbo. Silhouette. 4.0/6 speed auto.
1970galaxie is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2015, 12:19 AM   #4
cs123
cs123's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Can't think of anyone more deserving. Russ Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For all the technical support behind the scenes. Tech Writer: Recognition for the technical writers of AFF - Issue reason: Technical submission
I can't speak of Earls but have found the cheaper type more susceptible to galling. I've had the issue with a few fittings. No issue with Speedflow.
I've also found the better braided hose holds together well when cut were the cheaper braid unravels a bit and is slightly harder to fit on the hose end.
I love Holdens....
cs123 is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2015, 03:56 PM   #5
buggerlugs
If it ain't broke........
You pay for Earls but it is quality. Whenever cutting the stainless teflon hose, wrap a bit of tape around where you want to cut the hose, then cut thru the middle of the tape.........
Visitors welcome
Relatives by appointment only
buggerlugs is offline   Reply With Quote Multi-Quote with this Post
