So the local mechanic i'm taking my car too for a service tomorrow mentioned to me that he thought it would be a great idea to fill my tyres with Nitrogen, cost $30.
Reckons the type pressure is way more stable, tyres last longer and after a year the pressure is still all good, maybe only drop 1 p.s.i. in a year. Expensive car, expensive tyres, good idea, sounds good but I'd like to hear some user feedback. Have you filled your tyres with Nitrogen and what's your experience ? (Apoligies if this has been done to death allready, I havn't seen a thread on it, but feel free to post a link if this has been all done before). |
Havent done it, but air is 78.1% nitrogen anyway.
I use nitrogen although it has always been free.
As opposed to air which is 80% nitrogen "pure" nitrogen does not have very much oxygen or water in it and being relatively inert does not react with the tyres. Nitrogen is used in aircraft for the same reason except with the extensions that the tyres will not get ice in them or burn as readily in a heavy landing. I have never had problems and have found the tyres tend to hold pressure longer. |
woulda been better to do it in summer than winter. when the temp drops so does tyre pressure no matter what it's filled with.
$30 bucks sounds a bit dear I only pay about $2 a tyre & no never had a problem with it.
Never drive faster than your guardian angle can fly but fast enough so the devil don't catch you! |
#6 | |||
Would you go 6 months without needing to top the pressure up ? I currently check tyre pressure every 2-4 weeks and usually put a couple of p.s.i. in to top up to the 40 p.s.i. I run all round. |
#7 | |||
As far as the summer/winter thing is concerned the pressure change is bugger all, something like 1 psi for every 5 degrees and the temp of the tyre has very little to do with the outside air temp unless you have been parked for several hours. |
Interesting....if you had to pay $30 for it, would you ?
Nitrogen is inert thus it does not expand and contract relative to temperature . Motorcycle racers have been using it for decades as i have in all my road bikes aswell . Well and truly woth it but $ 6.00 per tyre sound a bit steep.
Chevy badges , the Polariser of the new millenia . |
#10 | |||
From the reading I've done most of the claims seem to be based upon the fact that the tyre pressure is more stable, holds pressure much longer, doesn't heat up as much...
Claims of increased fuel economy which appear to be frequent with those selling Nitrogen appear to be based on the claim that most people don't check their tyre pressures very often and one site I saw claiumed that studies show that around 94% of people are driving around with under inflated tyres. OTOH if one is allready in the habit of checking one's tyre pressures every few weeks then that would appear to leave the convienience of not having to do so, as the remaining main selling point. Appears that in the States you often have to pay to use the tyre pressure pumps at service stations. I still havn't formed a conclusive opinion and welcome all and any further feedback. |
Oo\===/oO
Just a marketing gimmick...no gain for the money outlayed.
But, FYI, the points made about Nitrogen not loosing pressure is based on the fact of Nitrogen Atoms being bigger then Oxygen atoms, meaning less leakage... The reason why planes and Racing cars use it is because Nitrogen doesn't contain moisture like compressed air does, making it less effected by heat fluctuating the pressure...
#13 | ||
I've been there, done that with Nitrogen and I have reverted back to good old air. At the risk of sounding very old school, in my opinion Nitrogen in tyres is not a good idea.
Why I hear you ask? Because once you have Nitrogen in your tyres you tend to think your tyre pressure concerns are over, so you get out of the habit of regularly checking your tyres. Once out of this habit, if you DO have a tyre at low pressure you are less likely to notice it. So you end up driving around on a under inflated tyre. At best this bad for fuel economy and prematurely wears out the tyres; at worst it compromises handling is potentially dangerous. Know your car and stick with the discipline of regularly checking your tyres.
2012 Territory - TS, RWD Diesel in Smoke |
#14 | |||
Formally Kia Chaser
Nitrogen is an inert gas, therefore it is not affected by ambient temperture changes... Compressed N2 can still contain moisture... Thats why we have to do a Dew Point test on all new N2 bottles at work.
#15 | |||
Old but happy
![]() Save my old bones from checking them myself. Naturally, I am not that clueless to not notice an under inflated tyre. |
#16 | ||
Fixing Ford's **** ups
Tyres leak air regardless of what's in them. Some tyres loose a little more pressure than others. Just the nature of the beast.
You can NEVER put straight nitrogen into a tyre, because air is always in there to begin with. There is no way known you can deflate a tyre fully to get all nitrogen in there. Or should I say, the ratio is automatically decreased. Using in race cars/bikes. They don't have the same tyres on there for that long. So different situation. Same applies to aircraft. In a nutshell, within the tyre trade. Fart in your tyre, it's more effective. It's a money scam, just like the person that originally bought it to the publics attention. If my memory serves me correctly, the well known business owner was going through a messy divorce and his franchise profits were up the creek. So he decided to pay ACA or Today Tonight to sprook about it and then proceed to rip off unsuspecting people with these claims. If nitrogen is so good, every tyre shop wuld be selling it, as it's a cut throat industry. So you have to ask yourself, which ones do and why wouldn't all the others if it's so bloody terrific? Last edited by svo supporter; 20-03-2012 at 06:53 PM. |
#17 | |||
If you give me $20 bucks, I'll paint your caps any colour you like. I'll even supply the paint and new valve caps. Also amazing, when it first came to the general publics knowledge, the caps were red. I surpose they realised red didn't go faster after all. ![]() BTW, I have also seen the sticker "nitrogen" near the valve as well. |
#18 | |||
![]() Nitrogen is a gas and just like all gasses when they are 'excited' by heat they expand. There is not an element within the periodic table that does not expand when heated. |
#19 | |||
Computer Torque Control
“Cookie Monster” 2018 BMW 118i M Sport 6MT Estoril Blue “Jill” 1997 Ford Falcon GLi Sapphire 5MT Regency “Sally” 1997 BMW 318i Executive 5MT Alpine White |
#20 | ||
Not unless your daily drive is a Formula One car...just another waste of money to suck in people with little knowledge of physics, chemistry, or general knowledge about cars and how tyres work.
The stuff you're pumping in is over 78% nitrogen...trust me, that bit extra won't make any difference. I thought the nitrogen filled tyre thing had passed long ago when people realised it was a crock. No idea it was still being offered... ![]() |
#21 | ||
I asked for nitrogen to be pumped into my tyres at the tyre place a month or so ago
he basically told me it is a waste of money Maybe nitrogen is to the tyre industry what paint protection is to new car sales ? |
#22 | ||
Nitrogen does work well from the point its' expansion is more stable than 'wet' air. It is the differing levels of moisture in the air which can change it's expansion rates, allowing a 'dry' gas to be easier to calculate pressures for racing.
#23 | ||
Now Fordless
Its a load of balony. Normal air is fine.
#24 | |||
Oo\===/oO
Exactly....its the moisture content in the air we breath creates the unstable environment in the tire... When water turns into a gas, it happens as a rapid expansion, greater then that of nitrogen. Nitrogen is more predictable in its behavoir, as it doesn't have the moisture to effect to pressure over temperature variables. Compressed air however, is dependant on humidity, and how good the moisture traps in the compressed air setup work.
#25 | ||
whats wrong with normal air? its been used for years!!!
almost as bad as people paying for bottled water!!! |
#26 | ||
XD Sundowner
i would need my own bottle the amount i drop and increase my tyres lol ( prado ) also serial tyre pressure checker , and 4 vehicles ....not for me .sure it has some minor benifits though ...just none for me
something old something blue |
#27 | |||
I really don't see a case for using nitrogen on road car tyres. If you are losing that much pressure in normal road use, then it is probably not due to temperature variation anyway. |
#28 | ||
heliums the next big thing.. reduces un sprung weight and improves handling.....
#29 | ||
GT-P With An Ego
I use hydrogen, lighter again.
Just be careful your burnouts don't go Hindenburg on you.
1998 DL LTD in Sparkling Burgundy, daily, mild 5.0L, high end stereo, slow'n'thirsty - 138.8rwkw. 2006 BF GT-P in Ego, 5.8L all alloy, Kenne Bell 2.8HLC, Nizpro Stage 2 ZF - 440rwkw. 2008 SY F6X in Silhouette, custom billet parts, beginnings of a stereo, much more - 340awkw. Ford Performance Club of ACT |
#30 | |||
