Old 24-07-2005, 05:59 PM   #1
Mustang Dave
Default Tire pressure
What tyre pressure should I run in my street tyres when I go the track?
Mustang Dave is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2005, 06:40 PM   #2
GRNKPR
DPC PERFORMANCE Race prep
GRNKPR's Avatar
Depends on what tyres you have, on a street tyre you would be safe with 36 psi as a base pressure do a couple of laps then come in and check pressure again while hot staying close to or under 40 psi this is for circuit racing
: : i will excell with the knowledge i get on here : :
FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria
Ford Performance Car ClubFord Performance Car ClubFord Performance Car ClubFord Performance Car Club
GRNKPR is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2005, 07:13 PM   #3
eb six on boost
NO CARBON TAX
eb six on boost's Avatar
take cheap pump with ya and drop to 20psi max. ideal about 15 imo
THE WORLDS FASTEST BISCANYE BLUE EB FALCON WITH EB BLOCK AND HEAD!!! NO AU **** THANKS
Atomic performance engine, powerglide, coan converter, gtx55 turbo, 2000hp plazmaman water to air, 100mm throttle body, twin 50mm gates, side exit exhausts, 18 x 2200cc injectors, ems 8860 and race dash.......
7.83 @ 177 MPH
1100+ rwhp @ 40psi
the first 7 second sohc ! eat it
1993 eb falcon 15.4 @ 90mph (tow car)
eb six on boost is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2005, 08:29 PM   #4
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
It depends on whether your talking strip or track
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2005, 08:35 PM   #5
GRNKPR
GRNKPR's Avatar
also dont you spell tire as tyre
Old 24-07-2005, 08:43 PM   #6
toby123
Boosted TQE FTW
Seeing as though its in the Drag racing section, i think he might be talking about the strip....
Daily Driver: 08' ford ranger
Project: EF Falcon Turbo... Not long till back on the road.....
toby123 is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2005, 08:52 PM   #7
ratter
ratter's Avatar
Good point. but I found it under new posts, not the drag racing section
that's my excuse and i'm sticking to it
Old 24-07-2005, 08:56 PM   #8
Mustang Dave
Um strip out:
Couple of laps? :
They are not great tyres (very hard compound) 235/60/15 hankook dynamic :
Old 24-07-2005, 09:07 PM   #9
rodderz
rodderz's Avatar
Everyone I've talked to has kept their street tyres at normal pressures...ie with 18's 38psi or so will be fine
Some people have tried lower psi's into the low 20's but it slows down mph and the harder sidewalls of street tyres wont expand out enough as per drag tyres to get the grip without losing roll
rodderz is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2005, 10:15 AM   #10
SLY XR8
Who's your Daddy now
SLY XR8's Avatar
If your going to run street tyers 25 is good if your wheel spinning drop them a bit more. wouldn't go lower than 20 though.
If they are a hard compound as u say do a nice burn out get them hot and sticky.
Powered by the twin screw from bluepower
Thats What I'm Talking About!!!!
SLY XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2005, 07:10 PM   #11
PhantomXR8
Now a FG XR8 in Nitro
PhantomXR8's Avatar
Question
I reckon you're right legend, the low pressures could be preventing these powerful cars getting higher speeds although they get a decent launch. I was with Chris and Wade last Wednesday night the WSID. Chris just had no grip where Wade did have. Wade got a great time in the end due to a good launch, his mph was down though. His tyre pressures were very low, if this was the reason for his lowish mph it would have also hindered his ET to a point. When I was karting we would run low pressures but was told that if they were too low it would prevent a higher speed at the end of the straight, thus more time was spent reaching that point. I suppose a little test would be to try and push you car yourself with different pressures, come to a compromise between pressure and effort to push. If you're finding it hard to push you car I'm thinking your engine would suffer as well somewhere in the equation.
Nitro XR8 6 Speed Manual - SS Inductions Growler, Herrod Headers John Bowe exhaust 0-60kph 2.46 secs
PhantomXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2005, 07:17 PM   #12
Citric GT
Its yellow, NOT green!
Citric GT's Avatar
I think it also depends how likely your car is to loose traction. With my stock EL XR8 its not worth lowering tyre pressures because I don't have enough power to have traction problems.
EL XR8 sedan - low & loud
FG XR6 Turbo ute - Auto & Lux pack
Citric GT is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2005, 07:30 PM   #13
Mustang Dave
Normal tyre pressure it is! :eclipsee_
Thanks
Old 25-07-2005, 07:57 PM   #14
PhantomXR8
PhantomXR8's Avatar
Thumbs up
Exactly, your car will roll nicely at high speed.
Old 26-07-2005, 06:35 PM   #15
rodderz
rodderz's Avatar
Definately have high pressures in the front too, the less rolling resistance the better
Old 27-07-2005, 11:28 AM   #16
Pilch
X-Series Club Moderator
Pilch's Avatar
Surely the type of tyre would have a large bearing on the most appropriate pressure, along with power output etc.
I was recommended 18psi in 235/60/14's, and maybe lower! Seemed low to me, around 25 is what I would've expected as a good starting point. If I run my normal wheels (17's) on the strip, i would just use normal pressure!
PROJECT - '77 XC Falcon 351C - Click Here
DAILY - '05 Ford Territory
BIKE - '12 Suzuki GS 500
Pilch is offline   Reply With Quote Multi-Quote with this Post
