1999 Ford Fairmont Ghia
I have head that three other long serving Ford sixes are also on the chopping block:
-The Cologne V6 (2-4L SOHC V6) -Vulcan V6 (3.0L OHV V6) -Canadian Essex V6 (3.8-4.2l OHV V6) What's going on? |
He has, the Knack..
Probably for similar reason the I6 was canned. Ford want to use a global v6 to cut costs
2010 BF MKIII Falcon wagon "EGO" Workhorse, stock as a rock 2004 BA MKI Futura - Now the wife's For Show: 18" Kaotic Shadow Chrome, King SL all round, Cadence Amp, Kenwood 12" Sub, JL Audio 5x7's, Scuff Plates, MP3 Connector For Go: SVI LPG, K&N Filter, F6 CAI, XR6T snorkle, XR8 catback, Magnaflow metal cat, Pacemaker headers, Underdrive, Thermostat, Custom tune, DBA4000 Now with baby seat and toys 175.6 rwkw www.bseries.com.au/King_Nothing |
![]() Join Date: Jan 2005
Yep all 6 cylinder engines are being replaced by the Duratec V6's worldwide.
HSV - I just ate one!
great...... ford obviously didnt learn anything from the lesson of bringing the american falcon to australia in the early 60's...... something designed for one region WILL NEVER work well in another region that it wasnt designed for
#5 | |||
#6 | |||
_Oo===oO_
Each Ford divsion will tune their version of the duratec to suit their customer bases needs/desires.
The Duratec was listed as one of the worlds top 10 engines this year, putting it int the company of an Ausdi engine and a couple of 'sigh' bmw straight sixes. None too shabby. |
#8 | |||
_Oo===oO_
Built Ford Tough
The engines are fine, it was the suspension/chassis that the yanks got wrong when sending us the Falcon, and import cars still don't have it right because everything is a compromise!
Black on white '83 SWB F100 C6 auto 351C on gas and on the ground --> Project Thread '55 F100, just a roller at the moment, new project Silver MY12 Volkswagen Amarok |
Oo\===/oO
Global engine means global perfomance parts!
#11 | |||
#12 | |||
windsor user
look at the differing amounts of aftermarket parts between windsors and clevelands as an example.... |
#13 | |||
Location: Under the bonnet, trying to keep as clean as above!
#14 | |||
#15 | ||
_Oo===oO_
May be...
#16 | ||
Guy that posts stuff
Ford is obviously trying to stop the bleed. Key is to reduce complexity and logistics and r&D costs.
Take note of some of those engines. Very unmodern. SOHC or OHV. I think lumping the I6 in with it is a bit harsh, as currently it has more technology than the duratech engine slated to replace it (its just not alloy). But then again the choice was all alloy I6 in 2010 or go V6. Obviously with the money at ford like it is, they have made the economical choice. Ion having dribbled and exploded, did not help, as they bailed out of the Alloytech casting facility. What a dumb idea, Ion could have been casting all the Six cylinder falcons and commodores engine blocks. Not to mention other components. |
#17 | |||
1966 Ford Mustang coupe. 347 stroker, PA reverse manual C4, TCE high stall converter, B&M Pro Ratchet, Edelbrock alum heads, Edelbrock intake manifold, MSD ignition, Holley Street HP 750 CFM carb, gilmer drive, wrapped Hooker Super Comp Headers, dual 3" straight through exhaust, Bilstein shocks, custom springs, full poly suspension, American Racing rims, Open Tracker roller spring saddles and shelby drop. Still to go - Holley Sniper EFI with integrated fuel cell. |
#18 | ||
Apparently the Canadian Essex was a really good V6 was a really good V6 similar to the Ecotec but obviously inferior to Barra.
For that matter apparently the Ecotec V6 was on Wards best engine list and is still in production in America. |
#19 | |||
The Barra is getting canned as well because of the emissions. the main problem is that the time the Barra takes to warm up is too long. a cold engine has bad emissions. this is one of the few things that is stopping this engine from passing the upcoming emissions. on a more positive side though, turbochargers and superchargers help reduce emissions dramatically as they are recycling what would normally be left tfor exhaust waste. look forward to a lot more factory turbocharged, supercharged and twin versions of both in the future. |
#20 | |||
BOSS 5.4L Enthusiast
#21 | ||
Snoopping
Economy of scale. It's alot cheaper to build a few variations of the same basic engine for use in multiple platforms, then build a totally different engine for each platform. The other engines mentioned are even older then the Barra so Ford is taking advantage of the emissions to retire these engines.
#22 | |||
LPG > You
LPG Lovers Association President & Member #1. ![]() ![]() |
#23 | ||
Green with Envi
I love the Inline 6 as much as most of you guys but at 4 Litres it's limited in use to cars with pretty long bonnets.
A V6 will allow Ford Australia to shift things around a little and play with weight distribution. I am going to miss that growl though. This duratec bizo better have a good noise.
--- 2005 BA MkII Falcon XR6 --- --- 2005 SX Territory Ghia ---
#24 | |||
LPG > You
#25 | |||
Canning the Barra MIGHT cause some pain and I will miss it, BUT it had to be done. The iron block takes too long to heat up, thereby affecting emissions and cold start economy. The trade is that Ford Aus gets to become the RWD development centre for Ford Worldwide AND keeps Falcon alive until at least 2020 assuming the 2012 model has a 8 year lifecycle. Hiring Allan Mullaly, ex head of Boeing as CEO and Kuzaks as product development czar is the best thing FoMoCo has done in a long time. Mullaly awarded $4B worth of contracts to Hawker-DeHavilland which is an Australian firm several years ago as he believed that our engineers (aero or otherwise) get the job done right and at the best price. Stop being pessimists (yes it's easier), start being optimists.
BA2 XR8 Rapid M6 Ute - Lid - Tint -18s 226.8rwkW@178kmh/537Nm@140kmh 1/9/2013 14.2@163kmh 23/10/2013 Boss349 built. Not yet run. Waiting on a shell. Retrotech thread http://www.fordforums.com.au/showthr...1363569&page=6 |
#26 | |||
All except some racing derivative and later 4.0 litre sohc engines were pushrod overhead valve engines, with a single camshaft between the banks. Later, the Cologne V6 largely replaced the Essex V6 even for British-market vehicles. The block is iron. The highest output is for the 4L SOHC which has: 216 horsepower and 269 ft·lbf of torque at 3000 rpm. (161kW/361Nm) Ford Essex V6 engine (UK) Unusually, the Essex V6 was built so that the same block could serve in both Diesel and petrol applications, although the Diesel version never reached production. Traces of its Diesel design lie in the necessity for dished piston heads to reduce the compression, and the very solid construction. The Essex V6 is a heavy engine, weighing significantly more than the Rover V8. Canadian Essex V6 (3.8-4.2l OHV V6) - 90 degree vee. One source states that the Essex is instead a copy of the Buick V6 engine [1], done since Ford needed a working V6 much faster than building one from scratch would take (the Cologne V6 couldn't meet fuel economy requirements, and the all-new Vulcan was several years away from production at that point). The Canadian Essex was a pushrod design featuring aluminum heads, which reduced its weight considerably and made it a very powerful engine for its size. The Mustang version was updated for 1999 with Teflon-coated pistons, a variable length intake manifold, and a more open cylinder head. These bumped output up by 40 hp (30 kW) to 190 hp (142 kW). Vulcan V6 (3.0L OHV V6) The Vulcan was a clean-sheet design using the metric system. The engine block is built by Sherwood Metal Products, the intake comes from Ford's Essex Casting, and the engine is assembled at Ford's Lima Engine plant in Lima, Ohio. 3.0 L SFI Vulcan V6 155 hp (116 kW) 185 ft·lbf (251 N·m) Taurus 2000-2005
