Old 06-12-2006, 05:30 PM   #1
QLDxr
Question Zetec Start up Problem
Hi Everyone,
I treated my 'good lady' to a 2004 Zetec Auto a few months ago and although she is very pleased with the car, it has a niggling problem on start-up.
On the initial start in the mornings, the engine speed is 'hunting', therefore when you select 'Drive' or 'Reverse' the car jumps about for the first 20-30 seconds and then it's fine.
Any ideas would be much appreciated.
Thanks in advance,
Mike
QLDxr is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2006, 05:38 PM   #2
Ives
Ives's Avatar
What do you mean by "the engine speed is hunting"? When I start my car in the morning it normally idles at 1000rpm for about 1 min or so, and then goes back to 750rpm.
But even if I was in a hurry, my car didnt "jump" when I select "R".
Maybe bad fuel?
Ives is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2006, 06:22 PM   #3
QLDxr
The idle speed flicks between 1400 and 1000, hence causing the car to kangaroo down the street when no gas applied!
Already been to Ford dealer...they're as much use as a "handbrake on a canoe"!!!
Cheers,
Mike
Old 06-12-2006, 09:08 PM   #4
Piotr
Non-Regular Member
Could simply be a ECU issue. Reflash the ECU it sounds like a Cold enrichment and idle speed calibration issue.
Piotr is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2006, 11:20 PM   #5
Steffo
LPG > You
Steffo's Avatar
When I start my car (05 Zetec WP), it sits at 1250rpm while the temp gauge is on stone cold. Does this for about 2 min. Temp gauges jumps up, slows itself down to 1000rpm, then eases down to its normal 750rpm idle.
LPG Lovers Association President & Member #1.
Steffo is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2006, 12:26 AM   #6
MITCHAY
Air Flow Meter possibly? RPM hunting can sometimes be caused by a faulty AFM.
MITCHAY is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2006, 12:46 AM   #7
Piotr
Non-Regular Member
Fiesta uses MAP sensor
Old 07-12-2006, 12:56 AM   #8
MITCHAY
Yeah forgot to put- "If they use a AFM" sorry. I thought they were much the same thing though?
