Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Furious Performance
Furious Performance Specialists in Automatic Transmission & Fluid Transfer Products Website Link
Old 02-02-2020, 06:50 PM   #1
dato1
Exclamation Territory six speed gearbox
Territory 2010 SYII six speed gearbox help
I have a plastic Sump Filter 6 speed Automatic Transmission ZF6HP26 Gearbox
Do I stick to the Ryco plastic pan and filter and use a Full synthetic ZF Lifeguard fluid or Dextron 6 Fluid.
Or do I do a metal pan conversion with the ZF lifeguard six fluid or Dextron 6 fluid.
Like to service it myself.
Thanks
dato1 is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2020, 09:42 PM   #2
AngryBfXR6
Default Re: Territory six speed gearbox
There's a lot more to it then just draining the oil.
I'd suggest getting the steel pan as it's cheaper long term, ZF lifeguard or Nylon SYNATF which is ZF certified. I used it for years with no problem.
If you plan to service it yourself, Google the ZF service procedure or find it on these forums as I think someone has uploaded it already.
Sent from my SM-G960F using Tapatalk
BF XR6 N/A - Pacemaker 4490 headers, Pacemaker S/S cat and catpipe, S/S Hi-Flow rear muffler, Autotechnica Custom Intake, DBA Gold series slotted and cross drilled rotors on the front
210.8hp at the wheels
AngryBfXR6 is online now   Reply With Quote Multi-Quote with this Post
Old 03-02-2020, 11:27 AM   #3
XR6 John
Search ZF servicing at home on this forum. New steel pan and filter costs you $185. I used Penrite ATF BMV and also did a flush to remove the old oil in the torque converter (not for the faint hearted) If not flushed I would follow up with another oil change to put clean oil throughout. The steel pan come has a drain plug. I'm changing mine every 60km from now on.
XR6 John is offline   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
