ANy suggestions on a full system upgrade for my 200KW AUII XR8?
BOSS 5.4L Enthusiast
Alot of people use Pacemaker Extractors and seem to be quite happy with them.
Im sending my AUII XR8 220 in for an Exhaust soon and G & D Recomended Pacemaker Extractors into High Flow Cat's then 3 Inch Mandrel Bent system. |
#3 | |||
![]() Join Date: Jan 2005
If you want to bump up your low to mid range torque, I can recommend the Paccie Tri-Ys. I had these on my AU2 Forte V8 auto with HF cats and single 3" mandrel bent system, and power was around 205 fwkw (149rwkw, from memory), up from 127rwkw (175fwkw) standard.
It all counts
di fillipo system front to back would be a very good upgrade.
NWOLB 8 built by Autotech Engineering tuned by KPM
Herrods headers used to be made by defillipo.
Sorry to hijack this thread, but I've purchased a set of factory XR8 extractors and cats for my AU V8 ute (175kw) .. will installing them help or hinder performance, sound? Engine is stock with single 2.5" (or 2.75"?) system and pseudo-performance muffler ..
Rod. |
If they are series 3 extractos, then they will help. If they are series 1 or early series 2, they are the same as what you already have.
Uterus M.I.A.
If your doing extractors on a N/A 5L may sure they are 4-2-1 (Tri Y) design. The comp series or 4-1's are just to big for the 5L and you loose out on the bottom end.
I'm swapping mine back to tri Y's. As far as exhaust goes the general feel is dual 2 1/2 mandrel or single 3"
Right out sideways
click the links in my sig, sedan is paceys and twin 2.25, ute is stock headers with Lukey 3" cat back
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302 |
#10 | |||
Giddy up.
#11 | |||
![]() Rod. |
#12 | |||
Giddy up.
XB in parts...
Don't the T series guys recommend Hurricanes for their 8's ?
#14 | |||
Uterus M.I.A.
#15 | ||
AU3 Winged Windsor
xr8fella how much louder does the do both those systems make the cars
#16 | ||
AU3 Winged Windsor
sorry bout the "does the" bit in that last post
#17 | ||
Giddy up.
You can hear the difference between the auto and manual in XRfealla's sound clip's, and I think the single system with stock header's on the ute sound's much deeper and better than the twin.
#18 | ||
Right out sideways
the twin is alot louder when your into it, at idle the the single is louder.
The twin has a cackle as you can hear, whereas the single is more of a bark. I personally prefer the twin, but the single still sounds sweet on song. But in actually loudness over stock, with WOT the twin with extractors would probably be well over twice as loud, the single cat back on the ute would be just on twice and loud
#19 | ||
PHATXR8
The twin sounds the best - gotta lov the cackle... 2 nice notes!!
#20 | ||
Ive always had twin systems on my windsors, they are especially good on modifyed engines,cams,headwork,induction etc,especially big solids cams.
Both my utes have single 3" systems,both work extremely well,and have no loss of torque down low,and produce better power and torque from idle than the factory systems they replaced. Specs and click the links to listen, you will get many opinions with a thread like this... mine... car: AU2 XR8 PURSUIT exhaust: 2 1/2 into 3" single extractors: 1 7/8" 4 into 1 difilippo heads: stock gt40P cam: standard tickford (200kw) other: 3" HPC steel pipe,70mm tickford TB, custom CAI. idle: click takeoff: click the missus... car: AU2 XR8 exhaust: 2 1/2 into 3" single extractors: 1 7/8" 4 into 1 difilippo heads: stock gt40P cam: Herrod motorsport other: chiptorque chip idle: click takeoff: click |
#21 | ||
I have the Hurricane headers with some hi flow cats (don't know the name) running a 2.5" twin system with 2 oval offset 14" Magnaflow mufflers - one on each bank and - a custom merge pipe and a rear twin 2.5 in and out rear res it still has the nice note but there is no drone at all
Regards Alan FG GT in Lightning Strike 5th anniversary edition in manual 1 of 25 And an 2019 MD Mondeo Trend Wagon in Platinum White |
