Old 20-06-2013, 02:04 PM   #61
mik
mik's Avatar
Default Re: Changing AU auto transmission fluid
Originally Posted by au3xr6 View Post
I'm assuming your car has a dipstick. not standard on the AU but some do have them fitted if the transmission has been out. the reason the got rid of the dipstick is people were overfilling causing problems. it is hard to overfill if there is no dipstick as it just runs out the hole.
and people were also putting the wrong oil them, which also can cause problems.
Old 20-06-2013, 02:12 PM   #62
DRAGN6
DRAGN6
DRAGN6's Avatar
EXACTLY, mik, spot on mate
Any time one buys a new car, it always pays just to do a full service of everything [yourself] then YOU as the new owner, knows the job has been done right, from the start
Which is what I personally, am working on doing
DRAGN6 Build Thread
My Previous Rides:
LOTS, But I'm only listing my most recent!!
  1. 2001 AU XR6 [New Daily]
  2. 1999 AU Classic [DRAGN6]
  3. 1992 EBII with too much to list! [sold and bough DRAGN6 as a 'stocker']!
DRAGN6 is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2013, 02:59 PM   #63
TRAU BLAU
Originally Posted by transolutions View Post
No worries mate hope it all works out
G'day,how's Sydney?You sound as if you know BTR boxes.Is the Speed Transducer another common leaking point on AU's or is the fluid likely to be coming from the exten housing gasket on my ser 3 wag;162k.
TRAU BLAU is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2013, 05:20 PM   #64
transolutions
Mate it is a lot more common coming from the speed sensor when the o rings goes old and hard but have seen the extension housing leaking to its hard to say not looking at the car but it is easy to pull the speed sensor out and change the o ring that would be the first thing I would do if your not sure were it is leaking from and you are working on it yourself
transolutions is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2013, 12:57 PM   #65
TRAU BLAU
Thumbs up Re: Changing AU auto transmission fluid
Thanks mate,will change the o-ring this w/e.I also read from old blogs[2009etc]that fluid could also come out of the breather which is also on top of the housing.It all being so hard to acess without the bright lights & hoist doesn't help but I s'pose life wasn't made to be easy.
Old 21-06-2013, 04:11 PM   #66
transolutions
Yer start with that oring you can get bright torches these days oil really shouldnt come out of the breather unless you over full or getting really hot good luck
Old 24-07-2013, 01:46 PM   #67
TRAU BLAU
Wink Re: Changing AU auto transmission fluid
G'day Sydney,Yeah I changed the o-ring on the speed transducer but the leak is still there.From what I can see it looks as if it's the extension-housing gasket which has splined-bolt heads[not sore of correct term]so I s'pose it'll have to be a pay workshop job & expensive.That, or just change the fluid & forget about the leak.Any advice appreciated.
Old 24-07-2013, 05:59 PM   #68
peterljohnson55
peterljohnson55's Avatar
You might want to think about the following as well, while you are under there...
- rear main engine seal
- rear welch plug
- rebush oil pump, m/c cover, fit seal
If the trans is out you should get a full reconditioning ... (new?) torque converter, clutches, bearings, bushes, because you don't want to have to go back there - just removing and replacing is many hours, and costly if commercially done.
-- Ford Fairmont Ghia AU2, 3/2001, Tickford 4.0 I6, 12v SOHC VCT MPFI, sedan with IRS standard suspension --
----- ANJ is a practical beast, but still a lady, that I want to keep alive until at least2021 -----
-------- Preventative Maintenance Policy --------
peterljohnson55 is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2013, 11:37 AM   #69
TRAU BLAU
- rear welch plug
Thanks for reply but what you're talking about is thousands of dollars worth mate.Yes I agree the rear extension seal should be replaced but where's the welch plug?I mean the BTR 93 is working ok it's just a persistent leak coming down from the top of the extension housing.I'll see what the experts want to charge.No the trans is not out;I drive it every day.
Old 25-07-2013, 01:48 PM   #70
Evgeni
Auto Nerd
Evgeni's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: In recognition of the many hours spent scanning information for the benefit of AFF members.
Its probably the actual speed transducer. These can leak - you can pick up one from Ford for about $80. I think they are cheaper online.
You can also get an extension housing service kit that contains the bush, rear seal and gasket. Can't remember if the bolts are 12point or spline drive, but either way, the socket is going be the cheapest thing you will buy. You will however need a press to get the bush out and obviously the spacers needed to press the bush out - if in fact it is leaking from the rear seal. Worst case scenario, take the extension housing off and take it to a transmission shop and see if they will change the bush over for you.
Evgeni is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2013, 05:36 PM   #71
DRAGN6
DRAGN6
DRAGN6's Avatar
Quick followup to my issue guys
Spent $250.00 having FLUSH etc done on my box, but found metal and other crap in the box, so it's beyond it's used by date sadly
NOW have a 5 speed ready to go, just picked up the Pedal Box and now just need the ring gear and cable, then should be set to go
I appreciate ALL the previous help and advice, but I've now chosen to convert to 5 speed manual and get the most of the performance from the XR6 that I can
I know that this isn't the thread for it, but IF anyone has any info/ cables / ring gear to achieve the conversion, then please inbox me.
Cheers,
Dave
DRAGN6 Build Thread
My Previous Rides:
