27-02-2008, 12:48 AM | #1 | ||
I just got new tyres put on on the weekend and had a wheel balance done aswel, but since then i have noticed this kinda shaking in the steering wheel when im driving on the highway and im not sure what it would be?
27-02-2008, 01:02 AM | #2 | ||
www.lukehimself.net
Warped rotors can cause this but if its only started when you put the wheels it probably wouldn't be that. Where the wheels aligned or just balanced?
27-02-2008, 01:03 AM | #3 | ||
they call me Tibbo
out of round rotors
transmission mount intermediate steering shaft but....... if it has only happened with the tyres, I'd be rotating them to see if that fixes it
27-02-2008, 01:15 AM | #4 | ||
they might have stuffed up the balancing, what Tibbo said swap the tyres around or borrow some wheels from a buddy and see what happens.
27-02-2008, 09:17 AM | #5 | |||
27-02-2008, 10:07 AM | #6 | ||
New tyres should generally mean a balance. Something that any tyre place worth their salt does as a 'free' courtesy when you buy tyres. Hell, my local second hand place even does this.
27-02-2008, 10:22 AM | #7 | |||
gone fishing
27-02-2008, 12:53 PM | #8 | |||
Walking with God
All the best with it. GK
27-02-2008, 01:06 PM | #9 | |||
27-02-2008, 09:22 PM | #10 | ||
My mechanic is actually really good mate, when i got the alignment done they said there i didnt really need a balance there either so i dunno?
27-02-2008, 09:36 PM | #11 | ||
DUB
yeh mines got the same problem when travelling past 70kms or when gunning it down the highway. it just starts shaking. i think i need a wheel alignment now
27-02-2008, 09:56 PM | #12 | ||
www.lukehimself.net
I may be wrong here but I got the same thing when I had hub adapters which caused vibrations in the steering wheel. So maybe a quick one to just check your wheel nuts are tight. I know with new wheels you should tighten them up after a few days you put them on anyway.
27-02-2008, 10:24 PM | #13 | ||
Mate your mechanic is a joke. Your problem will be you need to get them balanced
27-02-2008, 10:32 PM | #14 | |||
27-02-2008, 11:58 PM | #15 | ||
I posted a thread where i was looking for answers for a similar problem. I found it was the tyres themselves, even after being balanced 4 times within the month by different companies! They were Kumho's, and boy I am glad they took them off!
29-03-2009, 11:56 AM | #16 | ||
I have the same problem too...It only happened when i put tyre pressure to 36psi on a cold day on all 4 tyres of my EB
Then massive shaking problems on the freeway. So i went back to 30 PSI on all 4 tyres and i think it might have slightly helped? But was still having the same problem so maybe the tyres are stuffed now and need a change? They still passed inspection when i gave it in for service...but they are no name brand tyres which say "max 140 kmhr" on em and 2 years ago Pedders told me they are "slightly out of round" |
29-03-2009, 12:18 PM | #17 | ||
Fixing Ford's **** ups
Wheel alignments have nothing to do with shaking what so ever. So that suggestion can be thrown over the shoulder. Unless of course it's that far out of wack, you'd screw the tyres within 20 K.
A tyre might have a heavy spot, as well as a rim. So when you pair the 2 up, you need weight on the rim to balance it out, so it doesn't shake. That simple. Very rarely you can put the 2 together and not need any weight on them. Yes rotors sometimes cause a vibration while driving, without being on the brakes. Very rare these days. However if you do suspect these, have the rim/tyre assembly balanced on the car, providing it's not front wheel drive/4 wheel drive/all wheel drive. Another shake problem maybe an out of round tyre. If that's the case and they are new, take them back and get replacements. They are covered by warranty, unless they're el-cheapo garbage. The mechanic that said they don't need balancing. All I can say is if he's a good mate, I'd hate to hear what he'd say if he was an enemy. Hope this helps . |
29-03-2009, 01:05 PM | #18 | ||
The 2 tyres I bought were back in 2006 and the other 2 came with the car when i bought it in 2006
The whole 'out of round' problem can come about to bad car suspension aye? I know the bloke who had the car before me never took care of it and I had to spend a lot on suspension but perhaps too late to save my tyres from getting out of round? |
29-03-2009, 01:12 PM | #19 | |||
Resident AFF detailer
29-03-2009, 01:53 PM | #20 | |||
Flairs - Truckers Delight
29-03-2009, 02:03 PM | #21 | |||
29-03-2009, 02:15 PM | #22 | ||
Balance your Tyres,,Rotors have nothing to do with steering Shimmy except when braking..
29-03-2009, 02:41 PM | #23 | ||
how can you buy new tyres and not have em balanced? That's your problem, your tyres have got the wobbles lol.... get em balanced that'll fix it ;)
29-03-2009, 04:55 PM | #24 | |||
Wanting a sprint!
29-03-2009, 08:21 PM | #25 | |||
Sorry mate, but suspensions can make the tyre go out of round. We'll use a stuffed shock as a good example there. Also edge wear on a tyre can cause a balance issue, even after they're balanced. Saw tooth edges are a good example there mate. BOLLY, sorry but rotors can cause a wobble at speed too, with out braking. The problem isn't that common these days, but it still exists. DAVE 93761. I don't understand your quoting there mate. Alignments are necessary to stop tyre wear. As just explained, saw tooth effect. So in short, it's the whole package, not just one particular thing. It'll be a process of elimination |
29-03-2009, 09:11 PM | #26 | |||
What you are talking about is uneven wear - I would call that wear and tear, not going out of round. So I think we are covering all bases for this guy's issues, but we are calling the issues different things. Long story short - get a balance and alignment, and if the problem persists, get new tyres (tyres more than 24 months old should be replaced anyway).
29-03-2009, 10:52 PM | #27 | |||
No, I think you're missing it. Tyres can have a manufacturing defect, that can cause out of roundness. Suspension components can cause the tyre to go out of round too. eg stuffed shocker, or on a front wheel car, lack of rotation. Noting to do with a tyre seperation. That's another issue to do with balance. Tyres over 24 months old being replaced???? Lost me there. Tyres over 5 years old, yes. That's unless you're going to go racing with it. But normal street driving, if they have legal tread, keep them on, unless you're feeling wealthy Alignment can cause an imbalance problem, only due to irregular wear patterns on the edges of the tyre. Getting an alignment alone won't solve a balance problem, nor will balancing a tyre with irregular wear patterns on it. Alignments are there to stop a tyre wearing. Yes, there's more to tyre wear issues, but in this case, it's not going to solve the problem. All I can say is, it's going to be a process of elimination. Try an off car balance first. If that doesn't work, have it balanced on the car. If that fails, ask for replacement tyres, if they are still new, as you have every right as a customer to demand that. |
30-03-2009, 12:12 AM | #28 | ||
i know pedders do alignment but do they do balancing as well?
30-03-2009, 12:45 AM | #29 | |||
ebayholic - no pedders do not generally do tyre balancing; they are a suspension shop. You need to take the tyres to a tyre shop for balancing (funny about that).
30-03-2009, 12:53 AM | #30 | ||
JC - thanks for letting me know. Is balancing one of those things that only need to be done for new tyres? Or does it have to be done every now and then like wheel alignment?
