Brembo Lover
Hi guys,
Now that my girlfriend has got her licence, she has started driving my car a little (for those that dont know, i lost my licence 11 months ago, so the car hasnt had much use since) and i have noticed that it makes a whining noise from behind the dash. It is only there when the engine is on and it rises and falls in pitch if you rev the engine. It is not the stereo, because it does it if the stereo if on or off. It doesnt seem to be as bad when the car is in R or D and in motion, but that could be because of road noise. I cant even begin to think what it is. It wasnt there when it was driven frequently, and i dont remember it being there when i started and idled the car every week or so since i have lost my licence. Only recently. I originally thought it must be that the gearbox or TC had no oil at the top or something, but it is still there after a drive, so i dont think it is that. The gearbox was serviced at 100K KMs, which is 11K KMs and about 18 months ago. Any ideas?? :|
Mine: 2007 BFII XR6 Turbo in Conquer with Sunroof, BFII Typhoon rims, CarPC, FPV Leather Wheel Hers: 2006 BF Super Pursuit in Vixen |
it could be the stereo... a bad earthing issue can cause speakers to make a so called whine when on or off.
01 AUII XLS Regency Red Ute 4.0L Egas Auto Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam, 1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD. Thanks to: EvilChief and SJW Performance |
#3 | |||
Brembo Lover
Fantastic Plastic
Just a guess , sounds like maybe 1 of the small coloured heater control hoses has come loose from its connection behind the centre face panel / that would explain the noise coming from around behind the head unit ?? . Might be worth checking. cheers.
I agree if it is coming from behind the dash it will be a vacuum line - there isn't much else back there that would whine with engine speed
The Ancient Warrior
Just a thought. You haven't got your head under the dash and moaning with fear, while your GF is driving the car have you?
#7 | |||
Brembo Lover
Nah, i thought it could be my heater or something, but that is all in the passenger footwell. Because i have a fairlane, it has climate control, so it is all digital - no vacuum lines that i have seen with the centre of the dash apart. Tomorrow, i will pull the centre part of the dash out and stick my head in there to see if i can get a better direction for the noise...
I am having the same problem with my el xr6. It doesnt seem to be the gearbox or diff, its coming from the front of the car and it happens both when the car is in gear or in neutral. It also goes up and down with the engine revs. Its really bugging me so if anyone knows what it is, any info would be greatly appreciated.
RIDE manual EL XR6 MODS 2.5inch cat-back, K&N high-flow filter, SS Induction cold air intake, Heavy duty button clutch, Spoiler Removed. Super Low King Springs purchased and getting installed soon!
Sly like a G6
Maybe someone installed a supercharger while you weren't looking...
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
Mine did the same, but only when I switched to lpg. Disappeared in time. Until I had the gas serviced. Now its back again!
Brembo Lover
I solved my issue.
I traded it on a brand new XR6 Turbo about 3 months ago ![]()
#12 | ||
Formally Kia Chaser
The only thing down there, apart from the cig lighter is the seatbelt pretension unit, mounted to the floor....
Kia Grand Carnival (2006) Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw HSV Clubsport R8 VY (2003) Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
A whining from behind the dash ? you don't have my ex wife traped behind there do you ?
#14 | |||
Now AU powered
Have been told it's OK, just the converter....although not there all the time.
First car: 1987 XF Falcon 'S' sedan, 82,000Km - 134,000Km Current Car: 2002 AU3 Falcon Forte sedan, 51,000Km when purchased - NOW: 81,000Km. |
#15 | ||
My kids think I'm cool
if it's more of a whistle type whirring noise I would say it's the alternator. Is it worse with the lights on/electrical load?
Mine has a whistle to it and it is the alternator, has done for years. Amazing how sounds transmit within a car, hope that helps.
2011 FPV GT 335 >My Build Thread< (Posts 3511-3515 has a compilation of most of the pics, page 118 @ 30 posts per page) BLUESTREAK built 5.2L flat-plane-crank VOODOO with 3.2L Intercooled Kenne Bell blower, 1000rwhp/746rwkw @ 8000rpm @ 20psi on E85. Built ZF with BLUESTREAK 2C Circle D converter. Unbloodybelievable... 2018 Ford Ranger RAPTOR 2013 Audi SQ5 |
#16 | ||
I get a constant whine in my S1 AU too, but it comes from the passenger seat. I keep telling her to be quiet, but she just won't!
Some people think I suffer from A.D.D., but they... Oh LOOK! A Chicken! |
