Old 08-01-2023, 08:05 AM   #1
kelshouse
Default Need advice please, how to remove water pump on KJ Laser
Hi everyone,
I have a 95 Ford KJ Laser 1.8 and I am in the process of replacing the water pump. I have undone everything and the water pump is free but I am unable to manoeuvre it out past either the top or bottom of the front of the engine.
I’m not sure there would be sufficient gap between the front of the engine and the inner frame rail to remove the pump upwards, noting there is also that part of the front engine mount bracket that is bolted to the side of the engine under the driver side of the intake manifold which protrudes forward of the engine.
On the lower part of the front side of the engine there is the oil dip stick tube which seems to be stopping the pump from dropping down and being removed past the bottom front of the engine. I have tried removing the oil dip stick tube but it seems to be very tightly stuck in place. Does anyone know whether it can be removed and if so how.
Can anyone tell me exactly how to remove the water pump.
Your help would be much appreciated.
Regards
Michael
kelshouse is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2023, 10:41 AM   #2
russellw
russellw's Avatar
Default Re: Need advice please, how to remove water pump on KJ Laser
Here is the diagram from the KF-KH WSM for the same 1.8L DOHC engine. The bits inside the dotted line can be ignored.
Old 08-01-2023, 02:55 PM   #3
kelshouse
Thank you Russell
Old 08-01-2023, 03:19 PM   #4
kelshouse
I have undone all of the stuff in the diagram, and the water pump is unbolted and loose, but I cannot get it out either by lifting it up past the front top of the engine, or lowering it down past the bottom front of the engine.
Old 08-01-2023, 03:31 PM   #5
prktkljokr
praek tih kl jo kr
prktkljokr's Avatar
here's one that was done before.
https://fordforums.com.au/showthread.php?p=1728271
prktkljokr is online now   Reply With Quote Multi-Quote with this Post
Old 08-01-2023, 06:17 PM   #6
kelshouse
Thanks prktkljokr, I'll have a look at the a/c pulleys etc to see if that's the solution.
