07-03-2005, 01:55 PM | #1 | ||
Da Shifty One
Howdy,
Whats the biggest size rims that i can put on my Fiesta. Someone said it was 19's?? |
07-03-2005, 08:22 PM | #2 | ||
Candy White GTI
lol. if you want to have no gearbox, diff and engine left then sure put 19's on :P
simhopper had 19's but it required guard work |
09-03-2005, 10:10 PM | #3 | ||
Fiesta Zetec
Bah, with some work I think U could get a set of 22s under there!!
Seriously, insurance will let U go only 1 inch wider than stock but any height, so 6.5in wide is the max....but if U dont care about insurance then U can get 19s. |
09-03-2005, 10:18 PM | #4 | ||
Number 5 is alive!
Why???????????????????
Kerry Tickford wings are for Tickford cars! "Experimental Racer" #6 1994 Gunmetal XG XR6 1997-1999 [B][COLOR=Red] 1994 Le Mans Red ED Back in a Ford XR. MA XR5 Mondeo |
11-03-2005, 03:22 PM | #5 | ||
Probably b/c anything bigger than that is illegal.... read the modification rules for your state.
25-03-2005, 03:01 PM | #6 | ||
Rollin
its usualy 1" wider and 2" bigger than the standard rims size avalible on the car
are the steel rims you get 14" or 15" on the fez if they are 15 then you can get 17" legaly now you can fit bigger wheels in there but depends on what you want to do |
25-03-2005, 03:12 PM | #7 | ||
Clio 182 CUP!
Well, i know with NRMA that when i went up an inch, they didnt care, they were just worried about width. You could have 20inch, so long as its not wider then they ask. But obviously, you cant get 20 inch with like 195 width
------------- Steven 'In fact, so good is the Clio 182 with the Cup chassis set-up that I feel moved to make a bold statement - I think it's the best hot hatch ever built.' (EVO Jan 04) |
25-03-2005, 10:11 PM | #8 | ||
Panther Black MK6
2inch bigger is the most u can go , after that u need a engineer cert
AP1 on its way In development stage 2 Carnt wait for the day ,NA all the way ,9000rpm with the top down |
25-03-2005, 10:29 PM | #9 | ||
www.lukehimself.net
19s on a Fiesta? That will be interesting...
25-03-2005, 11:01 PM | #10 | ||
http://www.ukfiestanetwork.com/index...image&img=1456
front and rear break conv as well Its mattmk6 from UKFiestaNetwork with simhopper's old wheels. |
20-09-2005, 11:13 PM | #11 | ||
striped
i know this is serious thread mining
but according to the RTA here in NSW http://www.rta.nsw.gov.au/registrati...i/vsi_dl1.html you can only increase the rolling radius by 15mm from what the largest combination is listed on the tyre placard now on my fiesta, which should be the same as your fiesta's, the largest combination is a 17x7 with 205/40R17 which gives a rolling radius of 595.8mm which means you can go up to 610.8mm in rolling radius, which includes some of the following combinations 215/35R18 and most importantly 205/30R19 if you could find tyres and rims in that size in regards to width, your rim cannot be more than 1" wider than the largest rim on the tyre placard, so you can have an 8" rim and your track cannot be increased by more than 1" which has to do with the offset and rim width hope that sorts some issues out for people and that black fiesta has got the damm rims that i want, ozzy racing RS GT's grrr |
20-09-2005, 11:58 PM | #12 | ||
Clio 182 CUP!
My fiesta doesnt have 17s on the placard.....
21-09-2005, 12:02 AM | #13 | ||
Fairmont Ghia
The tyre placards biggest combination lists the biggest rim that Ford sells with that vehicle. What Fiesta in Australia comes with 17s standard? None that I know of? I would have thought the biggest tyre size on Aus specific Fiestas should be 16 inch but if it isn't, then it must be a carry over from Germany.
(I know the car is German and therefore is not written to Aus specs for anyone who thinks pointing that out is worth their time, this is a different question) Tim |
21-09-2005, 12:38 AM | #14 | |||
Clio 182 CUP!
21-09-2005, 08:27 AM | #15 | ||
striped
well, on my placard, there are 17x7 listed
so if ever mr plod wishes to contest the legality of my 17's (heaven forbid) he is more than welcome to inspect it |
21-09-2005, 11:56 AM | #16 | ||
Fairmont Ghia
You'd be legally ok if only 15s were listed on the placard and you had 17 inch rims on... it's all good.
Tim |
