Old 01-07-2020, 02:11 PM   #1
Bossxr8
Peter Car
Bossxr8's Avatar
Default 7.3 V8 crate motor
New 7.3 litre V8 is now available as a crate motor. Bit more expensive than I thought it was going to be though. Can't wait to see how this engine goes once people start modding them, and throwing boost at them.
https://www.enginelabs.com/news/i-th...gine-released/
We’ve talked about Ford’s new 7.3L big-block engine — nicknamed “Godzilla” — both when it was released and when ProCharger announced its supercharger kit development . While ProCharger’s release of both a Fox-body and truck application confirmed that they saw what we all saw (a great engine-swap opportunity), finding one in a junkyard has been no easy task.
Ford Performance saw the same potential we all saw and just released a crate engine version of Godzilla aimed directly at performance enthusiasts looking to put a modern big-block engine into anything their heart desires. While the cost of entry into the Godzilla-swap game is fairly steep — MSRP is listed as $8,150.00 — being on the leading edge of something is rarely cheap.
The Ford Performance crate engine version of Godzilla is very similar to the production version as far as specs. However, you would have to order several different part numbers to get everything needed for a complete engine.
As delivered, the crate engine is advertised as having 430 horsepower at 5,500 rpm and 475 lb-ft of torque at 4,000 rpm, thanks to 10.5:1 compression and port fuel injection. The engine has a forged-steel crankshaft, aluminum heads (with great porting potential), and comes with the intake manifold and throttle body assembly, exhaust manifolds, ignition coils, and wires, and the same oil pan, oil cooler, and flexplate as included in production F-series trucks.
For control packs and engine accessory drives, Ford Performance asks customers to call its Techline, but we know for certain that the aftermarket is currently working on plug-and-play solutions and Holley EFI systems can be adapted to run the engines now, with a little work. While a potent package out of the box, it appears that all facets of the aftermarket are embracing the 7.3L, and judging by what we’re seeing, Godzilla will soon be a force to be reckoned with.
Old 01-07-2020, 04:38 PM   #2
jpd80
jpd80's Avatar
Default Re: 7.3 V8 crate motor
Those power ratings are for Super Duty, the same calibration in cars and F150 is 460 Hp and 500 lb ft.
I think that's about 345 Is and 675 nm. Might be fun in an older Falcon.
jpd80 is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2020, 06:16 PM   #3
blueoval
Critical Thinker
blueoval's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Well thought out and constructive posts.  A real credit to this forum.
Enter US engine builder Katech, and its new LT5 Track Attack crate engine, which was released to the world earlier this month.
According to Katech, its latest creation makes a cool 864kW (that’s 1159 horsepower in old money), and 1441Nm. Even in the heaviest of vehicles, that’s going to get you moving at one hell of a rate.
https://www.whichcar.com.au/news/gm-...out-of-the-box
"the greatest trick the devil pulled, is convincing the world he doesn't exist"
2022 Mazda CX5 GTSP Turbo
2018 Hyundai Santa Fe Highlander
1967 XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 AU2 75th Anniversary Futura
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2020, 06:22 PM   #4
Sprintey
Sprintey's Avatar
Perfect replacement for dusted 1VD-FTV, waaay cheaper too
I6 + AWD
Sprintey is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2020, 07:50 PM   #5
BA-XT
2003 BA Falcon XT
BA-XT's Avatar
Probably similar fuel ecomomy, cheaper to repair as well.... "But you can find Land Cruiser parts anywhere". True, but the money you'll save you can extend your trip out fir another 3 weeks anyway
2003 BA Ford Falcon XT
IMPCO LPG Vapour Injection.
DETAILING
Meguiar's NXT Car Wash
Collonite #845 Insulator Wax
Bowden's Own Happy Ending & Fully Slick
Chemtech CT-18 Truck Wash (Wheels & Chassis)
Bowden's Own Wheely Clean & Tyre Sheen
Bowden's Own Three Way Paint Decontamination Spray
OILS AND FILTERS
Nulon Full Synthetic 10w-40
Nulon Long Life Coolant
Ryco Oil & Air Filters
My Instagram Account: @ba_falcon2003
BA-XT is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2020, 08:07 PM   #6
ivorya
Mad Scientist!
ivorya's Avatar
Here's a new one from Revan Evan https://www.youtube.com/watch?v=mHTXBRRzo-s
780HP NA. Built long block, low compression setup for whipple 3L Blower.
ivorya is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2020, 09:10 PM   #7
Sprintey
Sprintey's Avatar
Sounds great too!
I6 + AWD
Old 10-09-2020, 02:23 AM   #8
chevypower
chevypower's Avatar
I really want to see the 1000+hp version in a two-door Bronco with the Sasquatch package.
chevypower is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2020, 02:49 PM   #9
Bossxr8
Peter Car
Bossxr8's Avatar
These are going to be great once they start becoming available on the second hand market, out of wrecked trucks.
Old 10-09-2020, 08:16 PM   #10
jpd80
jpd80's Avatar
The perfect upgrade for every four cylinder ute....
Old 11-09-2020, 03:00 PM   #11
Bossxr8
Peter Car
Bossxr8's Avatar
Even more impressive considering the heads are stock castings with a cnc port job, plus the cam and compression aren't optimized for NA.
Old 02-12-2020, 08:51 PM   #12
ivorya
Mad Scientist!
ivorya's Avatar
https://www.youtube.com/watch?v=DzJEKQTPMWA
https://www.youtube.com/watch?v=PgeAR7vnerQ
Old 16-01-2021, 10:49 AM   #13
ivorya
Mad Scientist!
ivorya's Avatar
Next development Vid:
https://www.youtube.com/watch?v=bbtPN37LvmU
Old 09-02-2021, 02:00 PM   #14
Bossxr8
Peter Car
Bossxr8's Avatar
https://www.whichcar.com.au/news/for...od-performance
Now available at Herrod Motorsport. Strong demand so far.
Old 09-02-2021, 02:10 PM   #15
lumen8
lumen8's Avatar
A controller for the 10 speed is great, it is mentioned in the article that Ford will be releasing an ECU for the 7.3 that will also control the 10 speed, for engine swap application.
Id like to see the transmission control side of it eventually become available as a standalone, to run that box in other things.
lumen8 is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2021, 02:39 PM   #16
Bossxr8
Peter Car
Bossxr8's Avatar
I'd hate to know how much a 10 speed would cost. Would be a freaking mint package of a warmed over 7.3 and 10 speed in an E series though.
Might take out a bigger mortgage and shove one in my NL
Old 09-02-2021, 07:21 PM   #17
Sprintey
Sprintey's Avatar
"and more closely akin to the dimensions of a traditional Windsor."
YES
"All Godzilla motors are assembled at Ford Performance’s engine plant in Windsor,"
It's even made there.
PS: the video where he is talking at Watson Racing in Michigan, I'm pretty sure the ED XR8 Sprint motors were built there.
I6 + AWD
Old 09-02-2021, 08:15 PM   #18
ivorya
Mad Scientist!
ivorya's Avatar
Palm Beach unboxing a Godzilla
https://www.youtube.com/watch?v=ZLuGFaNmSq0
Also talking about a new plug and play PCM they offer!
Old 09-02-2021, 08:24 PM   #19
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Just sell the house - can't race a house but you can live in a car
Old 09-02-2021, 10:55 PM   #20
XR Martin
XR Martin's Avatar
Anyone got the exact dimensions?
I reckon it would be quite a bit taller than an efi 302.
I know it's no heavier than a 5.4 DOHC.
2004 BA wagon RTV project.
Old 09-02-2021, 11:54 PM   #21
randel
randel's Avatar
Apparently 28.75”l x 23”w x 25”h and 536lbs (from Herrods)
Although these guys are saying about 25” wide
https://youtu.be/ML4SlsScnBY
Daily Driver - FG GS Ute
Toys - 351 XY Falcon and FG GT
randel is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2021, 02:04 PM   #22
Bossxr8
Peter Car
Bossxr8's Avatar
I would, but the missus and kids might not appreciate it
It's not that much taller. Fox body Mustang would have a similar bonnet height to an E series. Cause taller manifolds and 351's require cowl induction hoods on them, and those things pretty much result in next to no hood clearance on an E series. Looking at these pics it doesn't look so bad. Problem is the throttle body location, which is quite high right where the bonnet starts sloping down.
An aftermarket manifold, that makes the throttle body location better located at the front of the manifold, would fix that.
6 users like this post:
Old 10-02-2021, 03:09 PM   #23
66FAIRLANE
66FAIRLANE's Avatar
Just read the article linked. Got a hell of a chuckle out of this statement.
"An ingenious cam-in-block design makes this package far smaller than traditional overhead-cam V8s."
66FAIRLANE is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2021, 04:12 PM   #24
Bossxr8
Peter Car
Bossxr8's Avatar
Yeah I don't know what exactly is ingenious about it. It's cam in block like ford V8's were for about 7 decades.
Old 19-03-2021, 12:02 PM   #25
Bossxr8
Peter Car
Bossxr8's Avatar
https://www.enginelabs.com/engine-te...rds-newest-v8/
Pushing past 1400 hp with a blower. Makes 800hp NA set up for boost. Potential to make 900hp NA if optimized for natural aspiration. Heads are ported stock production pieces, stock crank and block. These engines will make great power will minimal mods.
Old 19-03-2021, 12:23 PM   #26
Cobra
Bear with a sore head
Cobra's Avatar
Yeah... I'm pretty sure it's been said tongue-in-cheek!
Cobra is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2021, 08:06 PM   #27
ivorya
Mad Scientist!
ivorya's Avatar
https://www.youtube.com/watch?v=CI5INrXHMTY
Aussie engineering
Old 11-05-2021, 02:32 PM   #28
Bossxr8
Peter Car
Bossxr8's Avatar
550 hp with just some 98 and tuning is seriously impressive.
Old 11-05-2021, 02:41 PM   #29
Franco Cozzo
Thailand Specials
What 'engineering'? Haven't they just put someone elses intercooler and someone else's (Eaton) supercharger on it?
It's more 'value adding' rather than 'engineering'.
Newsflash - put forced induction onto 7.3L V8 and it makes lots of power and lots of torque
It's interesting none the less but it's more marketing fluff though.
Old 19-05-2021, 08:08 PM   #30
ivorya
Mad Scientist!
ivorya's Avatar
https://www.youtube.com/watch?v=i09XYiXOfaI
Next vid
