31-01-2020, 11:37 AM | #1 | ||
Hi All,
I used to be on here a bit some years ago and found this forum to be excellent for info and tips etc....I am in the process of buying another Ford and need to draw on the vast knowledge out there.... I am looking at a BA Series 1 XR8 that has a Boss 290 FPV motor in it and a FPV badge under the bonnet so I feel it is real. I vaugly remember these being about back in the day but am not certain. It's not a GT but appears to be a dressed up XR8 with the 290 in it, leather interior etc.... Was this combo rare or is it an odd ball thing that someone has had made up from the factory....? Thanks in advance for any tips/info Cheers Nigel
When giving someone a piece of your mind...make sure it's not your last piece!!! |
31-01-2020, 11:39 AM | #2 | |||
Worth checking is if it's actually a 290 or a 260 with different rockers and badging.
My Ford Family... 2014 GT-F, Manual, Kinetic with Black Stripes 2021 Mustang Mach 1, Manual, Velocity Blue |
31-01-2020, 11:42 AM | #3 | ||
Hey, thanks for the quick reply....
That was my thoughts as well and now I'm wishing I had taken a pic of the FPV badge to share. How do you tell between 290 amd 260...? Cheers
31-01-2020, 11:45 AM | #4 | ||
Check the engine number. Both were built by FPV but with the engine number, you can check records to see which is which. Visually, not much to go by if it's been dressed up. Original rego should have the engine number. It shouldn't be the same if they have a 290 in there.
31-01-2020, 11:46 AM | #5 | ||
I've got a 290 in my XR8 but I put it in last year. It's also modded fairly significantly (348rwkw).
31-01-2020, 12:33 PM | #7 | ||
There you go. Knew the engine number would tell the story, just forget what to look for exactly.
31-01-2020, 12:40 PM | #8 | ||
Thanks guys....I'll find out the engine number and see what prevails
31-01-2020, 01:59 PM | #9 | ||
Also look at the build plate for the model code:
XR8 = 18335 GT= 18336 |
31-01-2020, 04:04 PM | #10 | ||
So the plot thickens.....
Engine number starts with FPVH Variant on Rego papers says 18335YK It has a FPV VIN plate under the bonnet on the radiator support revscheck says its a 6 cyl.... Owner says the guy he got it from thinks its legit however he has only had it for 2 or 3 years..... Interesting.....
31-01-2020, 04:12 PM | #11 | ||
Sounds like a mock up motor
31-01-2020, 04:15 PM | #12 | ||
Sounds like an XR8 with a 260 with 290 bling...
Another special 1 off order appearing in the jungle, figure that!
2022 RAM Laramie 5.7 2023.50 Ranger Wildtrak 3.0 V6 Premium Pack 2024 Everest Sport 3.0 V6 Touring Pack 2024.50 Mustang Darkhorse 6M Blue Ember + Appearance pack ETA Jan 25. |
31-01-2020, 04:21 PM | #13 | ||
31-01-2020, 04:24 PM | #14 | ||
VIN says 6 cylinder. Previous owner probably did an engine swap. Not an issue per say. But claiming it to be a 290 is rubbish.
I'd walk away personally...
2 users like this post: |
31-01-2020, 04:29 PM | #15 | ||
SO by the codes my guess is it was an XR6 Turbo manual that has had a 260 put in with a 290 plate on top
What is the best VIN decoder? Cheers
31-01-2020, 04:46 PM | #16 | ||
Can you provide the VIN, and we can have a look around?
Time to Make the Hippies Cry Again |
31-01-2020, 04:59 PM | #17 | ||
6FPAAAJGSW3S88696
The vin decoder I found tells me it is a Ford Meteor..... Thanks in advance Cheers
When giving someone a piece of your mind...make sure it's not your last piece!!! Last edited by haycait; 31-01-2020 at 05:20 PM. |
31-01-2020, 05:36 PM | #18 | |||
Former BTIKD
Edit.............. Falcon, 4.0L DOHC EFI VCT Turbo, Blueprint http://www.etisorigin.ford.com/vehicleSelection.do
31-01-2020, 06:41 PM | #20 | ||
That VIN comes up as a 7/2003 BA XR6 Turbo in Blueprint colour.
31-01-2020, 08:59 PM | #21 | ||
too many
2004 Mercury Silver Falcon XR6T - 5 Speed 2017 Platinum White Mustang GT - 6 Speed 2022 Blue Thai-Special for Daily Duties - Auto |
3 users like this post: |
03-02-2020, 02:27 PM | #22 | |||
Correct Sometimes I can get more detail, but that's all I could find too.
19-04-2022, 05:16 PM | #23 | ||
Ford T3 Partsologist
can a VIN number be found from the FPV Engine Number ?
we have a donor replacement engine for a BA XR8 - licensing wants to know the original VIN of the engine that's going into the current car
2002 Blueprint T3 TE50 Manual Koni Suspension # 161 T-Series Club of Australia - www.tseriesclub.org |
19-04-2022, 06:02 PM | #24 | ||
19-04-2022, 06:14 PM | #25 | ||
Fpvh4b11048 , sorry site wont let me do capitals
19-04-2022, 08:05 PM | #27 | ||
19-04-2022, 08:28 PM | #28 | ||
i've tried 6FPAAAJGSW4B11048 but m/cat doesn't like it
19-04-2022, 08:58 PM | #29 | ||
Former BTIKD
For SOME REASON IF THE FIRST WORD IS IN UPPER CASE THE FORUM DOESN'T LIKE IT............. as mad2 found
Maybe Russ knows
08-06-2022, 06:56 PM | #30 | ||
So I have a dumb question and an interesting question a well…
I’m sure it has already been asked but I can’t seem to find the answer so I need to ask the question. Can a 260 been modified to perform as a 290 The other question I have is what would you get for $13500 in 2005 if you wanted to with John Bowe Performance. And for those who are asking the question why haven’t I tried to get in touch with John Bowe Performance is that they don’t exist today. I have emailed John Bowe himself as he still races but he’s either busy or is sick of getting emails from others asking similar questions. |
