Blue Power Racing Developments The home of Blue Power. Website Link |
19-06-2010, 09:39 AM | #1 | |||
KenneBell Australia
if this car is detonating, it will need to be put on the dyno IMMEDIATLEY to determine what is the cause..........there are many things that could be causing it. If the car has a fuel supply issue, removing timing will not help, fuel delivery needs to be complete, and the timing needs to stay IN the tune, as it helps complete the burn and keep cyl temps down. If you have the same boost, but lean mixtures and remove timing as a "fix" you will raise cyl temps and risk an engine. Further to this, it is not company policy to have these boxes calibrated as to give users ability to "self tune" so unfortunately we cannot help there, perhaps if you give me a call on 03 9305 3000 we can discuss getting the car in here so we can see what is wrong with it. Regards Chris
Bluepower Racing Developments Proud Australian Distributors of Kenne Bell superchargers The Quickest, The Fastest, The Baddest Boss Blower of all. www.bluepower.com.au |
