09-03-2007, 09:52 PM | #1 | ||
ive un-done the bolt, bloody hard bastard. Any ideas off how to get the crank pulley off?? ive tried wedging things in but it doesnt look good at the moment.
09-03-2007, 09:54 PM | #2 | ||
Hmmmmm Mulberry....
Get a Pully puller. It will come off easy then.
09-03-2007, 09:54 PM | #3 | ||
they call me Tibbo
you need a harmonic balancer removal tool..
even with the right gear you come across a few stubborn ones..
09-03-2007, 10:15 PM | #4 | ||
do you have to remove the radiator to use that tool?? i dont really wanna drop the Aircon.
09-03-2007, 10:17 PM | #5 | ||
they call me Tibbo
yes it is best, but you wont loose your gas, the condensor can stay put,just remove the radiator and fans
09-03-2007, 10:49 PM | #6 | ||
My puller has shorter bolts
Don't need to pull the radiator out, just fans. Balancer only needs to move about 10-15 mm Need to be careful with the spanners but so don't damage radiator, I put a peice of laminex down there, thin but strong enough to stop damage from spanners |
09-03-2007, 10:52 PM | #7 | ||
Make sure it pulls evenly, and not to one side, otherwise you will have a ***** of a time pulling it out!
09-03-2007, 10:55 PM | #8 | ||
joesAu ,you need a special puller .the old bolt style ones don't work.coventry auto parts sell them for $150 od bucks.they are exspensive but you won't get the balancer off without one.if your in good with your local ford dealer/mechanic ,they might lone you one.
you can remove the balencer without pulling out the radiator, but you have to remove the thermo's
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17. |
09-03-2007, 11:06 PM | #9 | |||
Blown 5L coming
the reason the bolt was "...bloddy hard bastard..." is because they are tensioned to some rediculus foot/pound, not a hundred percent sure how much, but you will need a torque wrench to put it back on.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;) NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com Quote:
10-03-2007, 10:05 AM | #10 | ||
its ok i have the toorque wrench. Im goin to shops this morning to check out if i can find that pulller othererwise we'll have to try sumthing else.
22-10-2020, 01:21 PM | #11 | ||
You need the special $200 tool.
I am stuck in the same position trying to get the harmonic balancer off. |
22-10-2020, 01:45 PM | #12 | ||
Don't pay $200, this one is $165 posted.
https://www.ebay.com.au/itm/G-G-Tech...-/172750203493 You can also pick them up cheaper if you hunt around. Bill
22-10-2020, 08:28 PM | #13 | ||
search - Bf Fg harmonic balancer tool new solution $8 +$30 - in the search on this forum
This is how I did mine it worked a treat
XC GS OLD SCHOOL MUSCLE Audi A4 S-line quttro Xc falcon Previous fords- xc falcon 500 ,250 x flow 3 speed xc gs worked 250 x flow 4 speed xa Fairmont 302 auto wagon xb falcon 250 log auto 4 door xb falcon 200 log auto ute xc gs project - had to sell :-( xc gs 302 4 speed 4 door xc gs 351 auto 4 door zf fairlane 302 auto zk fairlane 250 x flow carb auto zl fairlane 250 x flow EFI auto xg ute , BA falcon dedicated gas xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5 |
