Old 27-07-2021, 10:32 PM   #1
Scruba
15+ Years!
Scruba's Avatar
Default AU2 Fairmont Ghia Head Unit Replacement
Hi all. My Fairmont Ghia has the factory sat nav in the dash.
I want to replace the CD changer with an aftermarket head unit with bluetooth as a minimum.
There's a plethora of units available with the looms to connect directly to the vehicle however, having the factory sat nav I'm looking for some guidance as to will the aftermarket hu and loom kit connect or can I expect issues.
My finger is pointing to the loom the aftermarket loom will connect to. 2nd loom I'm guessing is the sat nav connection to the factory hu?
Can I expect other issues with regards to amp etc as part of the premium factory system when fitting an aftermarket hu?
Sent from my SM-G960F using Tapatalk
AUII Fairmont Ghia Sedan Sparkling Burgandy
Work in progress
https://photos.app.goo.gl/7roViz57bb2Stkzx6
Scruba is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2021, 11:08 PM   #2
mad2
Regular...with metamusal
Default Re: AU2 Fairmont Ghia Head Unit Replacement
i presume you want the new HU to work with the steering wheel controls yes?
Old 27-07-2021, 11:28 PM   #3
Scruba
15+ Years!
Scruba's Avatar
Not important for now if not a simple setup
Work in progress
Old 28-07-2021, 05:14 AM   #4
lumen8
lumen8's Avatar
Do a search on here re. the amp, you will have to snip one wire on the factory loom that goes out of the factory hu and to the factory amp... and add an AV connector/end so it can plug into the aftermarket hu.
Offhand i cant remember which wire it was, (green maybe?) i remember I bought the AV ends that have a grub screw so you can put the wire in there and tighten it down. Alternatively you can just run 2 new AV cables from the hu to your factory amp along/under the sill covers. (Series 2's only have 1 AV wire hooked up but all the amps ive seen have the 2 jacks on them.)
Ive put a single din hu in the satnav fascia using the aerpro single din plastic that I bought on ebay, bought their loom also to do the job and my factory steering wheel buttons work with a pioneer hu, now i have bluetooth, hands free phone etc etc.
Although my car wasnt a factory satnav car so cant help you there, ive put a satnav fascia in it I got from an LTD and a different screen in the satnav part.
around 13 seconds you can see the single din hu...
https://www.youtube.com/watch?v=hQ3BoEamrao
I like the extra storage space I have now, and it sounds better despite the factory amp and speakers remaining.
lumen8 is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2021, 07:09 AM   #5
Scruba
15+ Years!
Scruba's Avatar
Wicked set up. Cheers.
Work in progress
