Powered by Ford
Who runs one in there AU? Is the 200kw cam big enough to run one? I don't want to change the 3.45 gearing but looking for abit more off the mark if a convertor will help? Engine is stock with only bolt on stuff.
Darren |
Just another mock-up..
I run one Daz.
9.5", 3500rpm. It really woke the big girl up.. I highly recommmend.. Mine is still running 3.45's. As mine is a 9.5" one and not a standard sized modified one, it allows it to flash to the rpm a lot quicker.. Also, retained lock up.. Do it..!
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
#4 | |||
Powered by Ford
Oh and sorry for stealing the lid off Jaiden also ![]() |
Hahaha.. no probs mate..
Drives great.. Even in traffic it's fine.. Only running a normal size cooler, but, my car doesn't get out a lot.. Here's a link to the one I've got.. http://www.tceconverters.com.au/prostreet.shtml
#6 | |||
Powered by Ford
I bought it secondhand with less than 1000kms on it. Was from a wreck.
I saw it and took the punt. I got the number off it and asked TCE. They told me it was a 3500.. The punt paid off. It only cost me $150. It was in a S3 XR8 originally. I think it's perfect to be honest. I wouldn't go a lower rpm.
#8 | |||
Powered by Ford
The guys there are always happy to help and are great to deal with..
From memory, the one in my car retails from $1050+gst, fitting is extra obviously. Hope that helps.
Critical Thinker
your car sounds pretty meaty Kris. Nice job. Doesnt sound like a Windsor. Sounds a lot tougher than I remember windsors to be.
#11 | |||
Powered by Ford
#12 | |||
Cheers Shav. Extractors and twin 2.5" exhaust, dumped at the diff, does wonders for the windsor..!! ![]()
#13 | |||
Good luck mate.. Keep us informed..!
#14 | |||
Powered by Ford
#15 | ||
5.6L x 2 pilot
![]() ![]() Join Date: Dec 2009
I too are running a TCE but closer to 3K stall. I first installed it with my 185kw Windsor and it was fine, but was probably closer to 2.8K stall then. When I installed it, I installed a PWR trans cooler bypassing the radiator.
On both engines (5L and 5.6L), it has performed faultlessly. Highly recommended. The only drawback that I have noticed is that your fuel economy may suffer around town. Cheers Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 ![]() 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
#16 | |||
Powered by Ford
What size is your tranny cooler & who did you get it from? |
#17 | |||
5.6L x 2 pilot
280x256x37mm. PWR - PWO5933. Not sure 100% that it is that one, but size is similar. I got it from and installed by Gentech (same as Bluepower) here in Canberra when I had the stally put in and gearbox serviced. Cheers Stu
#18 | |||
Powered by Ford
I just spoke with TCE and they said depending what i want out of the car i could go for a 2.5k or go with a 3k for abit more punch and if it's built tight it would most likely be around 2.8k like yours. He did say to ask the tuner on what he recommends also and will it effect the tune ... |
#19 | ||
Powered by Ford
Ok i just spoke to my tuning guy and he is pretty positive the 3k convertor will be fine with my tune and said all good ...
#20 | ||
5.6L x 2 pilot
Nice Darren. Do you have a time frame for this project?
Stu
#21 | |||
Nice.. Are you modifying your convertor's internals to stall higher or are you going the 9.5" one..?
#22 | ||||
Powered by Ford
#23 | |||
A lot of people have had their stock internals modified to stall to 3000, often with mixed results. Some don't feel like a hi stall, some are slow to stall up, and others have no problems. Going the 9.5" is the best option. Also, just to let you know, mine will stall up well while holding the brake and I have had no problems with it going into limp home mode.. Looking forward to seeing a vid of how it goes Darren..!
#24 | |||
Powered by Ford
#25 | ||
Fuel shmool... You didn't buy a V8 to worry about fuel economy..!
#26 | |||
5.6L x 2 pilot
Cheers Stu
#27 | |||
5.6L x 2 pilot
#28 | ||||
I daily mine...!! ........once a month ![]() ![]() ![]()
#29 | ||||
Powered by Ford
#30 | ||
Powered by Ford
Convertor ordered today ..... i gave into the credit card
![]() Now just find a tranny cooler & a place to do it for me ![]() |
