Old 31-05-2008, 10:04 PM   #1
jeffb
jeffb's Avatar
Default AU XR Cracked firewall above pedal box
This morning started off with a little rain, backing out the driveway I felt water dripping on my foot. After some investigating I have found that the pedel box has cracked the top of the firewall.
When depressing the brake the whole area flexes, so I can see why it happened, it is a really poor design.
I have searched and can see other people have had the same problem, but cant see what people have done to fix it. I am thinking I will have to take the dash out, drill out the cracked spot weld and weld some plate in there to stregnthen the whole area. I may as well do the clutch at the same time (its not cracked yet tho)
Has anyone had to do this? and pics on the fix? any tips?
jeffb is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2008, 10:23 PM   #2
philstoj
philstoj's Avatar
Mine was just a hole in the exact same place, the blasted crappy spot weld, and all i did to fix it was to use some urethane to seal it.
Old 01-06-2008, 07:30 AM   #3
jeffb
jeffb's Avatar
I have done that just to stop the water getting in, but it needs to be fixed properly as it will only get worse over time.
Old 01-06-2008, 08:32 AM   #4
rob_liss_lms10
rob_liss_lms10's Avatar
I used 2 part " stronger than metal " epoxy for mine. The epoxy has metal fillings or something in it. Smear it on and let it dry. worked a treat, haven't had a leak again.
Red bull gives you wings?: nahhh.... we got our wings from TICKFORD
rob_liss_lms10 is offline   Reply With Quote Multi-Quote with this Post
