15-05-2006, 03:31 PM | #1 | ||
Hey,
I have a 2door, 1980, 2litre, escort, manual Basically it goes like crap, I have been in stock 1200 corolla that goes harder. There are a few things going on: 1. It pings its head off at more than half throttle (I think I can fix this by adjusting the timing) 2. When I start it in the morning, even with a brand new battery it struggles to turn over, It sounds like it's half seized or something 3. It sounds like a tractor when its idling even after fitting a brand new muffler and an extra baffle. Apart from fiddling with the timing (it is now set to specs from gregorys manual) What should I do? |
15-05-2006, 05:47 PM | #2 | ||
V8's for ever
Check points dwell angle, cylinder compression , spark plugs and leads, and get the weber carb serviced by a decent tuning shop
15-05-2006, 05:49 PM | #3 | ||
PM me if you want
get a kit and service the carb yourself it is really not difficult at all.
Sounding like a tractor, 1. check your manifold exhaust manifold bolts are tight, 2. check the timing sounds lik,e it running very retarted timing or its way off.
15-05-2006, 05:50 PM | #4 | ||
V8's for ever
oh , your starter motor could need a look at. Check the brushes etc.
if it sounds like a tractor check you dont have a leak at your exhaust manifold. If unsure put a new gasket in and torque up the exhaust bolts properly |
16-05-2006, 01:24 AM | #5 | |||
tufLTD
18-05-2006, 01:25 PM | #6 | ||
cheers dudes, im onto it. will let u know how i go
