21-09-2006, 02:39 AM | #2 | ||
Over Thinker
http://www.mx6.com/forums may help
if not this is the closest nms I can offer from my 86 to 88 suppliment all the engine mounts and the gearbox settings engine damper mounts sub frame 62 nm / to engine 53 nm / torque stopper casing to engine 77nm/bracket to body 55 nm front and rear mount to engine 30 nm to subframe 53 nm manual flywheel bolts 105nm clutch bolts pressure plate to flywheel 27 nm belhousing bolts 119 nm starter bolts 40 nm bracket drivers side ......called intermediate shaft mount 63 nm /cv lock nut 240 nm air con\alternator bracket bolts .... none given (both of mine live on the front next to the radiator)
My car goes Brumm Brumm |
