26-04-2009, 05:48 PM | #1 | ||
1.6Lt Engine and Gearbox with A/C and complete with wiring harness if needed. The fuel tank is also available. from a KH
This engine is still in my laser so you can see how it runs and take it for a drive. I have just aquired a 1.8Lt engine so no longer need the 1.6Lt. I have just had the timing belt done and have a new oil & fuel filter for it. I dont have the money to pay to have the motor removed so its going cheap and you have to remove it. The price will go up once motor is out of car. Im asking 300 now and 500 once removed. call me on 0422 138 974 for an inspection and test drive. It has no oil leaks, rattles or knocks. Im also wrecking a 91 tx3 mainly panels are available as im taking the running gear from it. Im located at Beenleigh |
