10-10-2005, 09:45 PM | #1 | ||
I have just noticed this recently. Even when I lock my doors, my boot light stays on. Does anyone elses or do I have to drag my car back to the ford dealer?
Thanks |
11-10-2005, 07:22 AM | #2 | ||
Fairmont Ghia
I'm a little worried how you know this - how much time have you spent in the boot with all the doors locked? :
I have no idea if that is normal or not, I can try it later on when I get home from work though if noone else knows, with a time delay camera. Tim |
11-10-2005, 10:07 AM | #3 | ||
not here much anymore
didnt realise focus had a boot light?
RAM 1500
11-10-2005, 11:43 AM | #4 | ||
Tricolore Tard
Yep it sure does have one.
Didnt know it stayed on though... interesting dear watson Chris
11-10-2005, 12:06 PM | #5 | ||
Focus Rookie
i have never seen i boot light go on :
maybe the bulb is gone :S where bouts is this light?
04' Panther Black Focus Zetec Custom Euro Plates, ST side indicators, MK2 Badges, ST Snorkel, White 17"s, Exhaust, Springs, Volant Intake,Angel Eyes, Body Kit, St170 Lower Grill, F/C Throttle Body, DBA slotters |
11-10-2005, 04:37 PM | #6 | ||
I have only noticed when I'm driving I notice it in the rear vision mirror at night. The light is on the left hand side where the belt reel is.
11-10-2005, 05:03 PM | #7 | ||
Old enough to know better
Sounds like a problem with the switch in the rear hatch to me It shouldn't stay on. Try jiggling the switch a few times (wherever it is).............yeh, very technical suggestion I know
Manual 2003 Machine Silver 5 Door LR Focus Zetec. Mods: Ford Racing CNC'd cylinder head milled .040", 3 angle valve grind. Ford Racing Stage II camshafts. Ford Racing cam gears. Ford Racing long tube header. Random Technology hi flow cat. Herrod 2.25" stainless cat-back. Pipercross Viper intake. CFM 65mm throttle body. 2000 ported intake manifold. Herrod Custom SCT tune. Eibach suspension. Quaife ATB diff. Wilwood 13" brakes. Custom ST170 leather interior. www.cardomain.com/ride/2773918
11-10-2005, 07:22 PM | #8 | ||
Fairmont Ghia
I can confirm the light does not stay on with the hatch closed, indeed any other door to the vehicle can be open and it will remain off.
Here is the location of the light for those that wanted to know: Regards, Timmeh |
11-10-2005, 07:38 PM | #9 | ||
Tim your very technical minded do you have any idea where the switch is? I cbf taking it back to ford, for all the hassle of just a light.
11-10-2005, 07:46 PM | #10 | ||
Focus Rookie
wow i have a boot light.. the wire/bulb had fallen out of the holder thing and down into the void there..
11-10-2005, 09:43 PM | #11 | ||
Yup mines fine, but I may see if i can make it a little brighter. Typical me, never satisified.
RAM 1500
11-10-2005, 11:47 PM | #12 | ||
Zoom Zoom
I wanted to tap in one on the right too to brighten it... might just be able to use a brighter LED instead perhaps?
2012 Mazda3 MPS
12-10-2005, 11:16 AM | #13 | ||
yeah i think that would be the easiest way, i wanted to put one in on the other side too but dodgy wiring inc. died when i sold the Falcon.
RAM 1500
12-10-2005, 03:58 PM | #14 | ||
Curse the boot light...i've tried wiggling, fiddling...you name it...light still stays on, next out comes the hammer because in my book the hammer fixes everything
12-10-2005, 06:32 PM | #15 | ||
A chippy mate of mine always referred to his hammer as a precision "knockometer" (knock-om-eter). Sounds like what you need
12-10-2005, 07:30 PM | #16 | |||
Fairmont Ghia
In the photo above, it's located in the top of the locking mechanism, those other two small black things to the left and right are just locators for the mechanism, not switches. Timmeh |
12-10-2005, 10:57 PM | #17 | ||
Thanks Tim, I've fixed it without using a hammer...simply took the globe out, but I will look at the mechanism properly tomorrow. Thanks for everyones help, if not I will drag it back to Ford(again)
06-11-2005, 12:45 AM | #18 | ||
Finally got my boot light fixed, without using a hammer or any other tool. It was my aftermarket alarm that was causing the problem. Faulty pin in the bonnet. Happy it's fixed and no more locking myself in the boot anymore lol :sm_headba
