just wondering , i have AU 6 cyl is the fuel pump suppose to start priming when you turn your ignition on , because my au has issues starting when upto operating temp , i noticed there was no sound from the fuel pump when my ingnition is turn to the last stage before kicking over , and the fuel pump only starts when the engine finally kicks over ?
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak! AU SERIES 3 LIQUID SILVER BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS 123.4 GROUND TEARING RWKW'S , LOL |
When you turn the key 1 before cranking it over, you should be able to hear the fuel pump prime, and it should prime it self before cranking
If not you either have a fuel pump issue or a electrical problem
thats what i thought , no sound until engine fires , and seems to be using more fuel , what electrical probs could it be if not the pump ?
Relay or fuse
Formally kotevski22
Check for 12v at pump wiring when you turn the ignition on.
cheers .
relay is the one in the engine bay , fuse under dash , so if these are dodgy not enough volt go to the pump ? i'll check with multimeter 2mrw.
Smile
The fuel pump is controlled by the ecu.It is the trigger.If the pump relay and wiring are all ok then the computer isnt triggereing it.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
so how do i check that ?
if u can borrow or get ahold of another ecu
Smile
get a logic tester.It will tell you if the relay is getting a negative trigger from the ecu at that time. Have you changed the fuel filter?
#12 | ||
yeah , still the same after change
how do know if the pump relay is shot. logic tester ?
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak! AU SERIES 3 LIQUID SILVER BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS 123.4 GROUND TEARING RWKW'S , LOL Last edited by sleeper393; 07-07-2010 at 09:00 PM. Reason: missing |
#14 | ||
Smile
There will be no clicking at all.But the car is starting. You could always just swap two similar relays next to each other in the engine comaprtment. If it happens again its not the relay
#15 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
#16 | ||
cheers , appreciate all the input guy's, i'll have a beer for ya's.
#17 | ||
tried new relays , no change ,, its ****ing me off , can i hookup any low series ecu from any auto s/3 AU to see if that works and triggers the fuel pump , could loose wiring to the fuel pump cause an issue , got me beat why it only doe's it when the car has been for a drive an up to temp.
#18 | |||
AU DIE HARD
I would pull the pump out just to check it as well its not that hard to do have a look here for the info
http://www.fordforums.com.au/vbporta...article&id=692
#19 | ||
cheers, can the fuel pump play after it gets used , like i said it only plays up when the car is up to operating temp.
#20 | |||
AU DIE HARD
If you have a look at the 5th. picture in the link I put in the last post you will see what I mean. for the 15 min. it take to get it out I think its worth a look anyways |
#21 | ||
yeah sounds exactly like my issue , did you notice fuel consumption suffered ?
#22 | |||
AU DIE HARD
#23 | ||
LIFELONG DJR SUPPORTER
Sleeper, I think your clutching at straws looking at loose wires etc. The wiring for the pump is only one circuit. If it does its job cold, while running etc, its ok.
As for priming, the ecu senses fuel pressure at all times, and it won't prime if pressure is evident. That said, I think the paump is an issue as they seem to give issue when the car is hot only. Search for 'fuel' in posts by me to see how many times I have told people the same here. Mike
#24 | ||
thanks , yeah clutching at straws , frustrating but im at wits end, pump im leaning towards as from the start , thanks everyone for all your input , you all deserve a nice cold froffy.
#25 | ||
i used to get about 500km highway.
#26 | |||
#27 | ||
Just another mock-up..
good to see you got it sorted mate..!
Alot of good info by most!!!!
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
#28 | |||
#29 | ||
this is one reason why i run a fuel pressure gauge under the bonnet, makes it easier to diagnose a problem.
#30 | ||
good idea , so where do i place it on my intech , any pics , cheers.
