16-10-2006, 03:33 PM | #1 | ||
Does any one have advance extactors? are they any good.
16-10-2006, 04:44 PM | #2 | ||
everyone i know with a ford has pacemakers, i went with Hi Tech headers. stick to big and well known brands my opinion.
16-10-2006, 06:26 PM | #3 | ||
99FalconS
Best value Mod you can do.
I have pacemakers on mine. When i picked it up as soon as turned the key you could tell somthing had changed. |
16-10-2006, 06:43 PM | #4 | ||
yeah go pacies
01 AUII XLS Regency Red Ute 4.0L Egas Auto Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam, 1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD. Thanks to: EvilChief and SJW Performance |
16-10-2006, 07:30 PM | #5 | ||
Pacies for sure
matsAU1 |
20-10-2006, 02:47 PM | #6 | ||
Got the Advance extractors fitted today very impressed.
20-10-2006, 03:09 PM | #7 | ||
The Mod Bug Has Hit
what did they set you back.
Im getting paccie comps and 2.5" redback exhaust and tip fitted for $700 |
20-10-2006, 06:13 PM | #8 | |||
20-10-2006, 06:40 PM | #9 | ||
Just cruisin
I've had the advance extractors on for about 8 months now, im happy with them.
Do you have any pics just to see if there the same as mine?
___________________ BA LTD 5.4 |
20-10-2006, 06:42 PM | #10 | ||
I just got my cat back exhaust done in the last couple of months, now I'm thinking of getting some extractors... I can get pacemaker 4499's for $450 fitted, is it worth getting the comps? I spoke to the qld pacemaker distributor and he said unless I'm going to be putting out a lot of power they're not necessary. I'm not intending on doing too much performance wise to the car, so can anyone with non-comp pacies let me know how they go?
20-10-2006, 10:40 PM | #11 | |||
:eclipsee_ MY CAR :eclipsee_
21-10-2006, 10:03 AM | #12 | ||
Well ... if i get rid of my ute ... I have a set of PH4499 (non-comp extractors for the I6) sitting the garage ... NEW ... still in package ... so i might be selling them soon.
They are supposed to fit the facotry LPG vehicles ... but don't (without modification).
21-10-2006, 10:06 AM | #13 | ||
TL40 Wagon?
I am running the pacemakers PH4480's and i have always been happy with them. Brendan Mock and I have agreed to disagree about them but the before and after dyno results I got from fitting them with a decent exhaust too of course are in my gallery.
They worked for me. |
22-10-2006, 01:13 PM | #14 | |||
22-10-2006, 03:32 PM | #15 | |||
22-10-2006, 03:48 PM | #16 | ||
The PH4499s are meant to fit ... but on some they leave a 2-3mm gap ... other's touch the converter without heat shield.
In NSW you are meant to have a 150mm gap between converter and exhaust heatshield. So far I have replaced my header tank with a slightly smaller BA version and a couple of hoses ... this allows the converter bracket on the shock tower to move forward easily without fouling with the hose going to the radiator. But I have had a chance to make up a new bracket to move the converter forward and upwards a little to allow fitment of the extractors. my mechanic wouldn't allow it ... and 4 exhaust shops said the same as well ... they wouldn't touch it unless the converter was moved to allow more room.
22-10-2006, 03:53 PM | #17 | ||
So you have to have the converter relocated to fit extractors? Damn!
22-10-2006, 10:48 PM | #18 | |||
23-10-2006, 07:31 AM | #19 | ||
Tickford gas - is that the other 'factory' setup? dual fuel? Do you run the green top motor?
23-10-2006, 09:45 AM | #20 | ||
Flairs - Truckers Delight
You can get Tickford gas - dual fuel with a Vialle Converter, silver top motor.
or you can get egas - dedicated gas with a Vialle Converter, green top motor. Since both converters are identical, i would hazard a guess saying that it would be the same extractor situation for both.
23-10-2006, 11:34 AM | #21 | |||
