Old 02-11-2020, 04:15 PM   #1
pete r
Default AU1 XR8 Oil Cooler?
G'day,
I've got a factory manual '98 XR8, only had it for a few months and am still working out (or trying to work out) what she's had done during the last 22 years.
I've done some digging and found that oil coolers were only fitted to the AU2/3 220kw models.
Could anybody tell me if this is the same sort of cooler the 220kw models have? Unless it's a power steering cooler!
Cheers,
Pete
pete r is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2020, 05:01 PM   #2
pete r
Default Re: AU1 XR8 Oil Cooler?
Old 02-11-2020, 05:47 PM   #3
Peuty
Afterburner + skids =
Peuty's Avatar
Yep that looks like a factory 220kw cooler. Follow the lines, there should be a sandwich plate between the block and the oil filter. Filter should be a Z89a.
Oo\===/oO
Old 02-11-2020, 09:01 PM   #4
pete r
Thanks Peuty!
Does it look to be mounted the same/factory way as the 220?
The car is a bit weird, it has the white Tickford instrument panel, Momo steering wheel and gearknob (both old and worn) and the cam is different to the 185kw.
Old 03-11-2020, 06:55 AM   #5
crakrz
T3 TE50 Blueprint
Technical Contributor: For members who share their technical expertise. - Issue reason: Craig has shown and shared an outstanding amount of knowledge in the field of Tuning. Craig is only to happy to share with anyone that asks his knowledge on the EEC tuning system, in particularly in the use of Moates Quarterhorse and Binary Editor.
That’s not the engine oil cooler. I don’t have access to my car at the moment, but I’m pretty sure that’s the PS cooler. The engine oil cooler is mounted in the top/centre position directly behind the grill with huge braided lines.
crakrz is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2020, 01:08 PM   #6
Peuty
Peuty's Avatar
Yes sorry, crakrz is right, my bad.
Oo\===/oO
Old 03-11-2020, 04:46 PM   #7
macman
macman's Avatar
That is 100% the power steering oil cooler - not an engine oil cooler.
macman is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2020, 07:13 PM   #8
lumen8
lumen8's Avatar
Yep, V8 power steering cooler and that style was fitted to series 1's so id say it came standard on your ride.
lumen8 is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2020, 12:06 AM   #9
pete r
Terrific thanks guys!
Old 04-11-2020, 09:37 PM   #10
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Found it,,,
220 oil heater
Old 05-11-2020, 09:19 PM   #11
pete r
Ahha. Thanks Uncle!
