Old 19-12-2005, 11:04 PM   #1
Bluey33
Posts: n/a
Default Radio Security Code Error all the time
Can anyone help with loading the security code. I have the code but the Radio display now always shows 'Err'. I originally got the 'Code' display when the battery was replaced. But, since I loaded the wrong code a couple of times, I now keep getting that darn 'Err'. I did leave it overnight & tried this morning 0 no good. Tonight, I disconnected the battery for varying periods up to 30 minutes & tried again but still no go. Do I just wait for another 24 hours or what? Otherwise I will have to go to a dealer !! (The AU has the "Prestige audio System")
Thanks in anticipation.. :
Old 19-12-2005, 11:06 PM   #2
HLC
Audi S3
have you unplugged the radio from its loom and plugged it back in. try that.
i think we did that to my mums car. cause its had several replacement stackers and we mix up the codes sometimes. now sorted.
HLC is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2005, 11:10 PM   #3
Bluey33
Posts: n/a
Thanks HLC, that was fast ..I'll try that - I endevour to get back with the result. Cheers
Old 19-12-2005, 11:21 PM   #4
JC
Miami Pilot
JC's Avatar
That's not going to work - disconnecting the battery has the same effect as unplugging the loom (ie no power to radio).
What you need to do is to turn the car to the "On" position (ie accessories on, engine off - where the radio would normally turn on), and turn the radio on so the "Err" displays and leave it like that for at least 45 mins. Then it should go back to code, and enter the code in carefully.
If you get it wrong again, you need to do the above procedure but you need to leave the key in for a longer period of time.
Ford Performance Club ACT
Old 19-12-2005, 11:30 PM   #5
HLC
Audi S3
*shrug* i dunno. worked for us.
Old 20-12-2005, 01:19 AM   #6
Smoke Pursuit
Do wat JC says, leave the key on ACC for atleast 45 minutes then try, dont drive the car in this period or touch it however!
2022 RAM Laramie 5.7 V8 Here & awesome!
2023.50 Ranger Wildtrak 3.0 Premium Pack, 20 inch wheels.
2024 Everest Sport 3.0 V6 Touring Pack
Old 20-12-2005, 01:26 AM   #7
JC
Miami Pilot
JC's Avatar
Originally Posted by ShockWaveXR6na
Do wat JC says
Can't wait til my missus sees this - she might just get the idea! LOL.
Yes - definitely don't drive it or touch it at all - just leave the keys in until the Err goes away and Code reappears - the BEM needs time to verify that the key is in the ignition, and that's it'd not someone trying to steal the radio/car/whatever.
Old 20-12-2005, 07:45 AM   #8
Racecraft
they call me Tibbo
Racecraft's Avatar
it might take more than 45 mins.. THe error message flashes longer for every time the code has been entered wrong. It might take 4 hours if you have entered the wrong code 5 times for example..
Racecraft is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2005, 11:24 AM   #9
peterban
AULTD
peterban's Avatar
I had this problem with the LTD ( premium sound system ) the first time I changed the battery. When it asked for the code I carefully put in the number that Ford provided in my service book. I then received the dreaded ErrOr. Waited 5 Mins and Code came back, put it in again and the same thing., this time waited 15 mins and tried yet again with the same result.
I rang Ford and they said even a dummy can put the code in correctly, so down to Ford I went to find a dummy ( plenty of them around apparently ).
By the time I got there the ErrOr had disappeared.
They said $10 to put in the code, I thought a bit expensive but I wanted the stereo to work so I agreed.
They went to their computer and punched in the cars details and it gave them the code ( exactly the same as the one I had ).
Out comes the service guy ( yes I found a dummy ) and types in the code. ErrOr comes up again. He said the code must be wrong for the unit and then has to take the radio out to get the serial numbers off the back of the unit ( lucky they come out easy sometimes ). He went back to his computer and typed in the details and it gave him a new code number.
He couldn't put it in because the unit was showing ErroR so didn't charge me the $10 as it was now a warranty item instead.
I had to wait a couple of hours for the code to show again but the new code did work.
Worst case scenario is pay $10 to Ford for a new number
peterban is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2005, 11:37 AM   #10
BlackLS
Posts: n/a
PM the user SIDO. Give him your SIDO number and ask him really really nicely for the radio code.
Edit: Can't find the user. gotta check my PMs to see the username
edit 2: PM MR_SIDO with your SIDO and ask really really nicely.
Old 20-12-2005, 02:50 PM   #11
Steve D
Irregular Member
Steve D's Avatar
Actually, it's nothing to do with the BEM, the radio has its own processor (computer chip).
Steve D is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2005, 03:01 PM   #12
JC
Miami Pilot
JC's Avatar
Thanks - but you knew what I meant.
Old 20-12-2005, 07:01 PM   #13
Bluey33
Posts: n/a
Default It works
Thanx JC & others. Leaving the key turned to the accessory position (1st stop) worked. I appreciate all your help guys!. Now my wife can spend some time & tune it in again.
Old 21-12-2005, 09:54 AM   #14
Steve D
Irregular Member
Steve D's Avatar
It's always a nice feeling when the radio comes to life after you tentatively try to enter the correct code :1syellow1
She mostly takes : Ford Territory TX AWD (SY 2006)
*** Wheels magazine COTY 2004 ***
I usually get: Mitsubishi Magna ES (TL 2004)
*** Wheels magazine COTY 1996 ***
Old 19-06-2006, 10:26 PM   #15
ziggee
Posts: n/a
damm i entered it 3 times incorrectly tonight.... stupid code number waiting wating waiting.. and its cold out tonight... 45 mins hey, hmmmmm started @ 9:06pm..
Old 19-06-2006, 10:42 PM   #16
ziggee
Posts: n/a
just went out to ute, and code was showing up, so 1/2 hour tops yay!
Old 24-07-2006, 05:13 PM   #17
sednwol
sednwol's Avatar
So you are saying that you dont need to know the code to reset, simply leave the key in the ignition position and let the computer acknowledge the key and the code appears? Just bought our 2nd AU and no owners manual/no code!
sednwol is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2006, 05:16 PM   #18
b2tf
not here much anymore
b2tf's Avatar
No you do need the code, what JC is referring to is what happens if you stuff up entering the code.
Example -
put code in, code is wrong
delay
try again, get code wrong again
even longer delay
and so on.
RAM 1500
Old 24-07-2006, 05:21 PM   #19
sednwol
sednwol's Avatar
Thanks,guess I'll have to get the code from Ford.
Old 02-06-2010, 09:52 AM   #20
suryachikku
My code is 732, how can i enter in ford falcon 1999 model car i can see numbers frm 1 to 6 how can i enter 7
suryachikku is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2010, 09:54 AM   #21
JC
Miami Pilot
JC's Avatar
That's easy. your code is NOT 732. It is 4 numbers, and comprised of only digits from 1 to 6. You will need to go to Ford to get the real code, or send the serial number to ASL (site sponsor) and they can give you the code. You need to remove the unit to get the serial number.
Old 18-11-2011, 06:38 PM   #22
james79
Default Re: Radio Security Code Error all the time
hi how do i contact asl (site sponsor) new here and have a premium sound system i need a code for thanks guys
james79 is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2011, 08:22 PM   #23
JC
Miami Pilot
JC's Avatar
Welcome. ASL site is here: http://www.aslautomedia.com.au/
Old 18-11-2011, 11:27 PM   #24
foxtrot3
foxtrot3's Avatar
Hi. you will need to check your owners handbook as all units had 4 digit codes and some numbers did use a range of 0 to 9. On those units the "1" button advanced to the next spot and the "<" and ">" buttons scrolled through the digits. Cheers MD
HI
I'M MICHAEL
foxtrot3 is online now   Reply With Quote Multi-Quote with this Post
Old 20-11-2011, 12:50 AM   #25
james79
looks like i may have the radio code have to wait until monday.oh well heaps to do just brought a el wagon and a (el xr8 very rusty) putting all the xr8 stuff into the wagon. once that is done need to finish the xh v8 panel van conversion
Old 09-10-2018, 12:50 AM   #26
brianhog59
Mr LTD
Hi guys
Just brought a old 1989 DA LTD.
And the car had a flat battery.
So it has lost the Radio.
Just wondering that now it's 2018 that anyone knows how to find the codes .
Ford say it's to old for their records.
Can any one help please or know someone that can.
brianhog59 is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2021, 02:14 PM   #27
acropol
How put the radio code on my ford territory 2012 model
acropol is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2021, 03:04 PM   #28
11ford11
No code required for this model it’s programmed to the vehicle vin.
Try leaving ignition on for a couple of minutes if still won’t work get it scanned by Ford or similar
