Go Back   Australian Ford Forums > The Sales Yard > Spare Parts and Other Accessory Items > Genuine Ford Parts
Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member.
Old 27-05-2021, 10:48 PM   #331
DOC
DOC's Avatar
Default Re: Genuine Ford Parts
Hello GTLEGEND, I am chasing the boot badges for a BA MK2 XR8 sedan, please.
1. Falcon Badge
2. Series 2 Badge
3. XR8 Badge
DOC is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2021, 10:32 AM   #332
GTLEGEND
1. Falcon Badge
2. Series 2 Badge
3. XR8 Badge
Hi Doc,
Can get these badges for you.
The Falcon and Series2 is actually one badge, $50 plus postage if required.
XR8 boot badge, $65 plus postage if required.
Cheers,
GT
Old 28-05-2021, 03:15 PM   #333
GTLEGEND
FGX Base Ute Seat Parts:
Old 28-05-2021, 03:20 PM   #334
DOC
DOC's Avatar
Originally Posted by GTLEGEND View Post
Hi Doc,
Cheers,
GT
Fantastic, could I please get some instructions of where to send some money / details please and I will get this sorted in a lickedy split.
Old 28-05-2021, 06:55 PM   #335
orsm8
orsm8's Avatar
hi.
I have just checked ebay just now and Bayfords have the BA Falcon MK11 badge and the XR8 Boot badge. Cheers
orsm8 is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2021, 12:59 PM   #336
Dingo
Ford T3 Partsologist
Dingo's Avatar
Originally Posted by orsm8 View Post
hi.
why send business away when GT can help........................
see post 332
https://www.fordforums.com.au/showpo...&postcount=332
2002 Blueprint T3 TE50 Manual Koni Suspension # 161
T-Series Club of Australia - www.tseriesclub.org
Dingo is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2021, 11:11 PM   #337
In relation to this thread https://fordforums.com.au/showthread...68#post6584168
a) do new Genuine Ford Brake pad come with new caliper bolts?
b) What the price per caliper bolt for the FG Falcon and SZIi Territory?
c) Is there any discount for bulk buying caliper bolts?
Old 31-05-2021, 09:20 AM   #338
FairmontGS
WT GT
FairmontGS's Avatar
Hi GT, need the passenger side Windscreen Weatherstrip Insert Moulding for the Fiesta please. They are use once only apparently and this one has been on an off a few times
https://www.ogulftour.com/index.php?...ucts_id=262353
2011 WT.
Many thanks.
FairmontGS is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2021, 06:05 PM   #339
GTLEGEND
Hi Aussieblue:
a) I don't think so, some come with shims, but I need to get confirmation and get back to you.
b) Not sure which bolts you are referring to exactly so I have priced both as to change pads, you can just undo one slide bolt and lever caliper to one side, or to totally remove caliper from knuckle.
Caliper to slide bolts: Territory/Falcon $23 each normally $28.
Caliper to knuckle mount bolts Territory $6 normally $7.50
c). Discount is the same regardless if it 1 or 100, Ford don't offer bulk price discounts apart from the discount we are already getting for the Forum regardless of quantity.
Old 31-05-2021, 06:10 PM   #340
GTLEGEND
2011 WT.
Many thanks.
Hi mate,
$40 plus freight if need be..
Cheers,
GT
Old 31-05-2021, 10:02 PM   #341
i Aussieblue:
Thanks muchly.
Old 01-06-2021, 12:30 PM   #342
irvinnie
irvinnie's Avatar
Hi mate,
Does it have 4/6 Way or 8 way seats as they are the two different styles available for G6ET FGX?
I think it is the 8 way (seat control has fwd/back, front base seat up/down, rear of base seat up/down as well as back of seat tilt fwd/back)
But photo attached to assist, if you want a VIN number can also provide
Current rides
2014 FGX G6E Turbo Tuned by Walter@Oztek performance 504rwkw on e85/420rwkw on 98 with a PCMTec flex fuel tune
- 2010 FG GT (335 build #152) 437rwkw
- 2012 XR6 turbo Ute 345rwkw
- 2007 Force 6 (build #91) 330 rwkw
- 2010 GTE (build #2) 425rwkw
- 2010 50th anniversary turbo ute 365 rwkw
irvinnie is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2021, 06:44 PM   #343
WhiteKnight
Hi ,I have a FG G6E turbo (2009) and the red/white courtesy light has broken in the drivers door.
Are these fittings available?
If they are available what is the cost?
Thanks for your time.
WhiteKnight is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2021, 09:38 PM   #344
FairmontGS
WT GT
FairmontGS's Avatar
Hi mate,
Cheers,
GT
Please pm me with postage included figure and bank details GT. Thanks again.
Old 01-06-2021, 11:00 PM   #345
GTLEGEND
Thanks muchly.
Confirmed pads only come with shims, no bolts..
Old 01-06-2021, 11:54 PM   #346
GTLEGEND
A VIN would be great but sometimes not so accurate on some parts as it may or may not know whats fitted.
Old 01-06-2021, 11:57 PM   #347
GTLEGEND
From what I can see, the lens was only ever sold with the whole door trim, never as a single part.
The door trims are obsolete unfortunately.
Old 02-06-2021, 12:07 AM   #348
WhiteKnight
Thanks for trying
Old 02-06-2021, 09:34 PM   #349
Lee Fogarty
Hi GT,
Am chasing set of genuine roof racks for a 2013 ford territory. Please let me know if you have any leads. Many thanks
Lee Fogarty is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2021, 09:39 PM   #350
Lee Fogarty
Hi mate are you still chasing the door skin? I may have one available on one on my wrecks? Let me know
Old 02-06-2021, 10:04 PM   #351
GTLEGEND
Originally Posted by Lee Fogarty View Post
Hi GT,
Can get you new ones, not cheap though: Black $490 + freight, Silver $440 + freight.
Old 02-06-2021, 10:56 PM   #352
fordomatic
fordomatic's Avatar
Hey mate, chasing a header tank for AU falcon, doesn’t need the sensor.
Proud owner of the ugliest Ford ever made
fordomatic is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2021, 11:43 PM   #353
Magna
Magna's Avatar
If the Legend can't help, the red/clear door lights were also fitted on 2000ish VW Golfs, etc and you can get them from most pick-a-part wreckers.
Magna is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2021, 08:15 AM   #354
GTLEGEND
I might be able to get one of these, leave it with me for a few days..
Old 03-06-2021, 11:47 AM   #355
WhiteKnight
Magna , Thanks for the information
Old 04-06-2021, 11:42 AM   #356
GTLEGEND
I can get a NOS AU header tank without the provision for a sensor for $130 plus postage.
PM me if your interested.
Old 04-06-2021, 03:33 PM   #357
irvinnie
irvinnie's Avatar
Hi mate
VIN number attached in photo below.
Graeme
Current rides
Old 04-06-2021, 04:37 PM   #358
GTLEGEND
Hi mate
Graeme
Hi Graeme,
Can get you the 8 way side seat trim for driver seat. $130 plus freight if required.
PM me if you want me to get for you.
GT
Old 05-06-2021, 12:19 PM   #359
martyt100
I am after a Co2 sensor pre cat for a BF MK11 RTV any one know the part number ? I been advised to go stock.
TIA
Marty
martyt100 is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2021, 12:32 PM   #360
GTLEGEND
TIA
Marty
The sensor up on the exhaust manifold (assuming its a 4.0) has part number BA9F472A. Can get for $95 + postage (normally $110).
The sensor on the cat has a part number of 5W6Z9G444BA and can get for $260 + postage (normally $300).
GT
