Hi guys, i brought a SKF front wheel bearing hub assembly, it appears to be missing a outer gear? Maybe, not sure cant find any pics of the SKF, the site is double dutch, other bearings on ebay show a toothed gear on the opposite side to the studs. The part number i got was BAF4137A. Any clues? If i pull all of this apart on the car i am knackered as i wont be able to drive down and buy another. The one on the car is f*#ked.
AZZA
1967 XR Falcon Wagon, Super Pursuit…….for now. *****XR PARTS WANTED******* |
the toothed section is for the abs sensor to pickup on , if yours is missing maybe a reject or for another model
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak! AU SERIES 3 LIQUID SILVER BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS 123.4 GROUND TEARING RWKW'S , LOL |
#3 | |||
i believe you are reffering to the abs ring like this one?
Yeah i thought that was the case. The pics i saw described au non abs with a abs pic, so a bit of confusion. Thanks for info guys, i now know what the abs looks like. My car doesnt have abs, confusing ebay sellers.
AZZA
no prob's , happy its all good.
![]() Join Date: Dec 2006
You can use either hub, with or without ABS ring
If your car has ABS you can only use ABS hub IIRC ABS was standard from AU II series |
Thanks guys, i have new hub/bearing going in on Thursday as well as new front and rear lowered shocks and King Superlows, and a wheel allignment. Maybe 20's then, have 18's for sale.
AZZA
