Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link |
28-04-2010, 11:44 PM | #1 | ||
I have a AU2 XR8 i'm gearing up to do the swap to Tickford Premium front Calipers, i have the Calipers, and Brackets, i'm now keen to get the right disk's and some braided brake line's.
1. Can i please get some quotes on 329mm x 28mm Front disks, Slotted and Drilled, Im not sure on part numbers, i think one i got was RDA506G. 2. Id like a few to choose from with RDA and DBA as the two prefered brands, and out of curiosity the Kangaroo paw style as well. 3. Id also like a quote on getting a full set of braided brake lines, with the silicone over the top made up with stainless steel fittings. I am also seriously considering getting the Tickford Premium rear brakes from a TE50, so would want the brake line's to fit up and hopefully it will all be a straight swap. Thanks very much for helping me out, Cheers Heath |
30-04-2010, 04:55 PM | #2 | |||
Race Brakes Sydney
Heath the RDA slotted rotors are $310 a pair with the grooved and dimpled at $455 a pair .The DBA 4000 series slotted rotors are $726 a pair but these are Australian made and have been treated so you can't really compare them to the RDA ones.If the car is a sedan with traction control the braided lines would be about $295 all up.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop Street to track is what we expertise in Phone 02 9609 1101 sales@racebrakessydney.com.au www.racebrakessydney.com.au |
11-05-2010, 10:39 PM | #3 | ||
Thanks for your reply, i had actually forgot i posted this question!
In what way are the DBA 4000 series rotors treated? Are they the Kangaroo paw style too? Braided lines, My AU2 is a sedan XR8, it will have the front Premium calipers, and hopefully the rears aswell soon, But it DOESN'T have traction control, I can vouch fro this as i have left many powerlines in it! I didnt think any AU's had traction control? |
12-05-2010, 03:06 PM | #4 | |||
Race Brakes Sydney
MATTHEW PEARCE
13-05-2010, 11:43 PM | #5 | ||
Thanks for the explanation,
But i dont understand this part sorry, "Are you getting the hose bracket with the front brake set up and as i think they have one closer to the caliper" I'm not sure! Do you mean the position of the bracket for the brake line is closer to the caliper? i have bought the front calipers already and the brackets too, I had intended to simply buy some new bolts, fit them with new disks, and braided lines! I think that the standard lines for the Tickford premium brakes were braided, not sure but if that's the case i can always investigate going down that path. oh, Its a AU2 and its has IRS. Thanks again for your reply, Heath |
14-05-2010, 10:20 AM | #6 | |||
Race Brakes Sydney
MATTHEW PEARCE
14-05-2010, 10:21 AM | #7 | |||
Race Brakes Sydney
MATTHEW PEARCE
14-05-2010, 10:25 AM | #8 | |||
Back to Le Frenchy
I can answer a couple of questions here.
I needed to get custom hoses made up as there was nothing off the shelf that would do it, even the proper lines from Ford didn't work with mine. There is no difference between your rear brakes and the Premium rear brakes, they are one and the same.
14-05-2010, 10:41 AM | #9 | |||
Race Brakes Sydney
Thanks RG
MATTHEW PEARCE
20-05-2010, 02:50 PM | #10 | |||
Edit: Sorry, I've taken this off-track a bit. I will PM. |
20-05-2010, 02:59 PM | #11 | ||||
Back to Le Frenchy
20-05-2010, 04:41 PM | #12 | |||
Race Brakes Sydney
MATTHEW PEARCE
