Focus TDCi
quick question guys... my TDCi has 20k on the clock and i need to top up my coolant resivoir. can i buy coolant from autobarn or somewhere or do i need to buy stuff from Ford???
anthony |
Torquer
I'm not sure myself as I haven't had to touch anything since I bought the car, why is your coolant low?
2007 LT Focus TDCi S Bluefin Remap - K&N Apollo CAI - 2.5" Turbo-back Straight Pipe - 24mm Rear Sway bar - LT Zetec Bodykit - Black Projector Head Lights - LED Tail lights - DMB Overlays - Alloy Pedals - Scuff Plates - Sports Gear Knob - LV XR5 Springs - LV XR5 Wheels - Pirelli P-Zero Nero |
Old enough to know better
I'd get the Ford stuff. You have to be really careful mixing different colours etc. The Ford stuff is not that expensive
Manual 2003 Machine Silver 5 Door LR Focus Zetec. Mods: Ford Racing CNC'd cylinder head milled .040", 3 angle valve grind. Ford Racing Stage II camshafts. Ford Racing cam gears. Ford Racing long tube header. Random Technology hi flow cat. Herrod 2.25" stainless cat-back. Pipercross Viper intake. CFM 65mm throttle body. 2000 ported intake manifold. Herrod Custom SCT tune. Eibach suspension. Quaife ATB diff. Wilwood 13" brakes. Custom ST170 leather interior. www.cardomain.com/ride/2773918
FGII XR6, Focus Sport, XR
Sometimes if you mix different coolants then it'll start to go jelly like and clog up your radiator and will be damn annoying to flush out.
If it just needs a minor top up just use a bit of water. It should be at about a 33% coolant and 67%water, but it's only a rough estimate. How far below the low line is it??
Living Ford dreams
2011 Purple FGII XR6 2016 LZ Focus Sport BA XR8 Build Thread (SOLD) 1966 XR Falcon Build Thread |
Focus TDCi
its only just under the min mark. checked it while the engine was cold and also hot. i know not to mix colours... ill pop into ford tomorrow and pick some up.
Badly Focused
either use ford coolant or top it up with DISTILLED water, NEVER mix coolants...if you need to change coolant, flush the system totally...
RM
07 LT CL, CAI, timing, XR5 springs, LS Zetec wheels 16.045...0.05 of a second! I wanted a 15sec pass! 93 GSR/Evo3...too much to mention, 12.2sec 1/4, FOR SALE! *Maybe we don't try putting holes in things that sink, yeah?* |
Focus TDCi
Yeah its only a top up...not a change.
thanks for your help guys anthony |
#8 | |||
yum
2005 LS Focus LX
Nov05 | Manual | Black Sapphire 250,000kms. |
#9 | |||
Focus TDCi
Focus TDCi
ok got some coolant from Ford today.....1lt bottle was $41.... not happy about that but meh
bottle says to top up mix 10% concentrate to 90% water (im guessing)...can anyone confirm this seeing as BSSXR8 said about 33%...which i have always done with other cars? |
yum
Check the specs section of the owners manual.
2005 LS Focus LX
#12 | ||
Focus TDCi
ok...after a bit of reading...and a few calls to other ford dealers....turns out the dealer i went to sold me R150...which is a corrosion inhibitor that gets added to the cooling system. the other dealers said i need R152...which is correct after looking in the manual.
the service manager said that the difference in code is only because of the different size bottles the coolant is available in ![]() i called the dealer today and after about 30mins of arguing with them they still did not admit they sold the wrong stuff to me. |
Ford can never be wrong lol.. I noticed that my coolent kept droping slowly and I was constantly filling it up. Turned out that i had a leak in my radiator. Bloody FOCUS!!
